Old 06-24-2023, 09:15 AM
Catsteven Catsteven is offline
Default 1961 ventura change over from gen to alt with external regulator.
Not sure how to make the proper connections. Anyone have a drawing with an external regulator? I also have a few questions on using part of the old wiring.
1. Is it okay to pickup 12 volts from the aft side of the amp meter. Batt pwr on the old gen regulator.
2. Do you need to use a diode in the field or the relay wires to the gen from the regulator.
3. The # 3 wire is pwr to the regulator should that come from the ignition switch.
Old 06-24-2023, 09:40 AM
1. I would think it is OK to get the 12 volt from the amp meter.
2. Don't think you would need the diode when using a external regulator.
3. I would run that wire from same place you run the 12 volt to BAT connection on alternator?
Here is a pic of how an externally regulated alternator is wired:
Old 06-24-2023, 09:53 AM
Just saw your other thread.
you need the #4 connector on regulator to be the switched power connection?
See the diagram.
Old 06-24-2023, 09:54 AM
The drawing that’s attached is the one I used. I hooked everything as per the drawing. I didn’t hook up the number 4 wire because I don’t have an indicator light.
Everything seems like it’s working battery is charging amp meter is indicating charging.
The problem I’m having is when the car is not running the alt and voltage regulator is still powered and the regulator and alt is getting hot. Discounting the battery negative I get a spark like something is powered.
Do you think the number 4 wire needs to be hookup. I do have the number 3 wire attached to the hot batt. Per the drawing
Thanks for the info.
Old 06-24-2023, 09:56 AM
Okay thanks just saw your other reply. Last question what resister do I need to use.
Old 06-24-2023, 10:05 AM
Not sure on the resistance wire, it's for the accessory connection of the ign. switch. Probably because the alternator isn't running when in that position, it makes the light come on?
Are you using a regulator made for the alternator?
(not the one for the generator)
Old 06-24-2023, 11:43 AM
Yes using alt reg not the gen reg.
Old 03-17-2024, 08:44 AM
xlrate's Avatar
xlrate xlrate is offline
Default Gen Parts
Interested in the old Generator and brackets if you want to sell them?
