Old 06-04-2023, 03:59 PM
SD421's Avatar
SD421 SD421 is offline
Default 1966 Clock Delete Question
Hi anyone,
I’m going to forgo fixing/updating my clock
and go with the factory Clock Delete plate.
Is there suppose to be a plastic lens to go over it or is it left installed without it?
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 06-04-2023, 06:24 PM
Jeff Hamlin's Avatar
Just the Plate.
