Old 04-26-2023, 08:45 AM
joes455 joes455 is offline
Default Going back to solid rollers
Yeh I'm another victim of noisy hydraulic roller lifters.I thought the new version of the lunati lifters would be the end all cure all of the noise.Im willing to try a different lash setting technique that was recommended on this site,and that was to bottom plunger out then lash up 1/2 to 1 turn.Any input on this procedure is welcomed.
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 04-26-2023, 08:52 AM
chuckies76ta's Avatar
Those short travel Johnson lifters have been the best ones I've tried so far. I also like and run the Crower Solid lifters for years with no issues.
Old 04-26-2023, 09:20 AM
tom s tom s is offline
Morel makes Lunati.When I did my 383 engine we had one pair that was bad,they got exchanged and all were good.My next engine will use the new Coms with exchangeable cartridge.Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 04-26-2023, 09:21 AM
Comp!
Old 04-26-2023, 10:51 AM
AG's Avatar
AG AG is offline
I just installed the new Comps in a motor 2 weeks ago and they adjusted well and make zero noise.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
The Following 2 Users Say Thank You to AG For This Useful Post:
Old 04-26-2023, 11:29 AM
mysticmissle's Avatar
Lunatis work fine w a small trough ground into the body with a burr bit should you have to do this no. However I believe it will quiet your
Lifters as it has done a
Few sets I have dealt with and others. There is a thread buried in this section that shows this being successful many years ago I do not
Recall who the gentleman was that “pioneered” this morel fix
And to be fair I had to similarly modify some
Crower solid rollers for My ia1 almost 20 years ago
In each instance the lifter gets more
Oil to the top end and
Quiets down considerably in my humble
Opinion
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
The Following User Says Thank You to mysticmissle For This Useful Post:
Old 04-26-2023, 02:29 PM
Dragncar Dragncar is offline
BAM solid roller lifters with DLC option .
Good enough for big power Drag Week guys.
Have not heard a bad thing about them. They are based on a high end Crane lifter that is not available anymore.
Old 04-28-2023, 07:35 AM
Their are a few good solid roller vendors to choose from,it's just the hydraulic rollers are somewhat iffy
Old 04-28-2023, 07:46 AM
Misticmissle,the new and revised lunati have that raised port
Old 04-28-2023, 08:09 AM
Formulas Formulas is offline
will the grooved lifter bore mod do the same as the raised port?
or is it that a part of that feed hole is in the full diameter body
The Following User Says Thank You to Formulas For This Useful Post:
Old 04-28-2023, 08:52 AM
Yes it is probably the better option. it’s just more involved (motor apart) and it’s forever or atleast until
You bush the lifter bores
The notch made a huge improvement in quieting down these lifters and getting oil to the springs at idle
The set that I did that has the most miles on them we bought used w a new Howard’s hr, and it probably has about 1500-2000 miles since leaving my garage not a huge sample but a nice start
The second set I did on my
Motor probably only 300 miles so jury still
Out these are on an xr288
1964 540 gto
Old 04-28-2023, 09:25 AM
Murf Murf is online now
Hey MM, how do you clean those lifters up after cutting the groove in them?
I’ve got a noisy pair setting on my bench that I’ve been messing with. I can’t seem to get the parts out of the inside because the link bar rivet is in the way. Am I missing anything?
Murf
Old 04-28-2023, 09:31 AM
Soak in mineral Spirits and blow
Out really very little metal removed
1964 540 gto
Old 04-28-2023, 09:32 AM
1964 540 gto
