Old 04-21-2023, 02:56 PM
slowbird's Avatar
slowbird slowbird is offline
Default Let's try this for a forth time, lol
Well it's back together for the 4th time in a little over 2yrs. Sure hope this is it. First engine, killed lifter bores on dyno, second and third were thurst bearings got a total of maybe 600miles on those 2. I hope we can enjoy it for a while this time!!
The Following 2 Users Say Thank You to slowbird For This Useful Post:
Old 04-21-2023, 02:58 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
No use for you buying lottery tickets?
Old 04-21-2023, 02:59 PM
Scott65's Avatar
Scott65 Scott65 is offline
That's perseverance there. Good luck with it.
Old 04-21-2023, 03:30 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Those are nice valve covers.
Go fast, see Elvis!
Old 04-21-2023, 04:17 PM
Shiny Shiny is offline
Ditto
Way to hang in there... hope it goes well!
Old 04-21-2023, 09:05 PM
1968GTO421's Avatar
Admire your dogged perseverance! Best wishes for a well deserved success with no problems for years
GTOAA--https://www.gtoaa.org/
Old 04-21-2023, 10:28 PM
jhein's Avatar
jhein jhein is offline
I hope it's perfect.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 04-22-2023, 12:23 AM
Dragncar Dragncar is offline
Did you ever find out what took out the thrust bearings ?
Firing up the engine soon. I did the P Dude thrust trick and have .005 clearance.
Trying to cover all my bases. Its nerve wracking.
Hope she runs well for you.
Old 04-22-2023, 01:41 AM
Verdoro 68's Avatar
Hoping for the best! I admire your persistence.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 04-22-2023, 06:54 AM
chuckies76ta's Avatar
Wishing you great success. You'll be fine. Just make sure when you install converter that you have 1/8"-3/16" ( .125-.187) distance between the converter feet and the flex plate. Also make sure the pilot on the converter fits into the crank. Put a little grease on the pilot. Once you have the transmission bolted up to the block, and before bolting the converter to the flex plate, make sure the converter spins freely by hand. Pull the converter forward toward the flex plate and spin it by hand. There should be very little resistance.
Even before you install the transmission, test fit the converter against the flex plate. Check to make sure the flex plate bolts and not in contact with the converter. The pilot should install into the crank around minimum 1/8" - 3/16" past the chamfer on the crank. 1/4" is what my converter guy told me. The has to be room for the converter pilot to move back and forth inside the crank. This is something that is over looked alot of times.
I'm helping a friend who had a reputable company build him a converter that was suppose to be designed for a Pontiac and it turns out it was build for an LS engine so we were told. The pilot was binding in the crank and the feet were almost 1/2" from the flex plate when converter was installed.
Some info here also. https://www.yellowbullet.com/threads...crank.2156873/
The Following User Says Thank You to chuckies76ta For This Useful Post:
Old 04-22-2023, 08:47 AM
slowbird's Avatar
All that was done last time and still issues
Old 04-22-2023, 09:33 AM
Mike S's Avatar
Mike S Mike S is offline
I had thrust issues one time. It really sucks, I had to get a new crank after the first Caught it early on the second thrust failure, same engine.
I ended up limiting the converter feed in the th400 and solved the problem.
Old 04-22-2023, 11:20 AM
slowbird's Avatar
My feed is already limited. It is very frustrating to keep having issues with no solid cause to issue
Old 06-25-2023, 09:55 PM
slowbird's Avatar
Well finally got it back in and running. Sure hope all the issues are behind us.
https://youtu.be/5GeRjOPrqMI
The Following 3 Users Say Thank You to slowbird For This Useful Post:
Old 06-25-2023, 10:54 PM
67drake's Avatar
67drake 67drake is offline
Good luck on this one!
I’ve had a comedy of unforeseen things happen myself this year, but nothing like you dealt with.
It sounds great!
13.95 @ 102.1 on street tires @ 4055lbs.
Old 06-26-2023, 06:01 AM
steve25 steve25 is online now
I beg you now that it's running to send out a oil sample pronto!
You do not even have to pull the drain plug, just unscrew the filter some with the motor warm and collect that..
I hope you get a all's we'll report back and you enjoy the car fully this summer season
Old 06-26-2023, 06:38 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
what are you running for transmission cooler and lines B? good luck with it
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 06-26-2023, 08:20 AM
slowbird's Avatar
This cooler with -6 lines
https://www.summitracing.com/parts/der-54006
Old 06-26-2023, 08:56 AM
sdbob sdbob is online now
Wishing and praying all is well. After reading some of the problems guys have experienced I think geez how did my SD keep from having problems?
Old 06-26-2023, 09:49 AM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
