Old 04-11-2023, 04:29 PM
KGTO's Avatar
KGTO KGTO is offline
Default Dark sandalwood carpet
I had this posted in another section, perhaps here is more appropriate?
70 GTO has Atoll blue exterior with sandalwood (257) interior. I ordered samples from Ames and didn't match quite to the carpet. I pulled the door sill plate and the original carpet is very nice, but no match.
From what I could find, sandalwood should have dark sandalwood carpet. Can anyone direct me where to buy it? I'll post pics of the samples and the piece I cut from the original.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 04-11-2023, 04:30 PM
KGTO's Avatar
The triangle shaped piece is original, a shade darker. The light one is #19 sandalwood, the darker one is #32 dark gold (perhaps the closest but seems to have some green to it) the other which is too dark is #12 dark saddle which is incorrect. I also placed the #694G legendary sandalwood vinyl for reference against the edging.
I went to ACC's site but I still don't find the correct color. Any help is appreciated
1964 421 GP-Sold
Old 04-11-2023, 04:32 PM
KGTO's Avatar
Here are the pictures
ID:	610593   Click image for larger version
1964 421 GP-Sold
Old 08-14-2023, 09:54 AM
69Y97GP 69Y97GP is offline
Default Dark Sandalwood Carpet
KGTO,
Just wondering if you had any luck finding carpet. I have a '70 Formula with the same color carpet and can't find a Dark Sandalwood. I've attached a pic of the original tag on the underside for reference...(not that it helps us any)
Old 08-14-2023, 03:47 PM
KGTO's Avatar
Originally Posted by 69Y97GP View Post
KGTO,
Well yes and no....I received samples from several vendors, though ACC sells to most. I wound up choosing dark gold, its as close as I could get, and seemed to be the general consensus on the closest color. I took pictures of the tags on the factory OEM carpet which was just like yours, "dark sandalwood". It's too bad this shade isn't available as it's a widely discussed topic.
I purchased the carpet from Ames, went with the mass backed version which went in really well. It did seem a little longer than the OE, especially up the firewall. I can upload some pics tonight.
Sidebar, I've also run into the same issue on the package tray. It should be dark sandalwood, no one makes it. I bought a sandalwood tray from Ames and I need to have the color mixed to shoot it.
1964 421 GP-Sold
