Old 04-10-2023, 05:21 PM
gtobird's Avatar
gtobird gtobird is offline
Default Which 1.25" sway bar brackets / bushings / Links?
My 68 clone wagon has a broken sway bar bracket on one side, so I'm going to replace all of the bushings / brackets and links. Fortunately nothing is rusty, so got it apart in about 15 minutes. It already has a 1 .25" sway bar, which probably contributed to the broken bracket as it ripped apart right by one of the bolt holes.
Any recommendations on which set to buy? The car is running redline radial tires and I drive it like an old Grandpa.........(with a lead foot). Just ordinary street driving with a little bit of fun. Not sure if it should get rubber or polyurethane. I haven't seen rubber bushings that size listed for my car, but I suppose they are out there.
Old Joe
68 Firebird Convertible
68 GTO Clone (Tempest) Wagon
Old 04-11-2023, 08:16 AM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
I tried poly bushings at first and is was a harsh ride. Then back to rubber bushings for comfort.
Old 04-11-2023, 08:23 AM
gtobird's Avatar
Was it just poly bushings on the sway bar that you swapped back to rubber, or were you swapping the body bushings too?
Also, if your sway bar was a large diameter, where did you get the rubber bushings?
Old Joe
Old 04-11-2023, 11:29 AM
David Jones's Avatar
I have a 1.25" T/A bar and a WS6 steering box on my GTO. Honestly, a couple of the best mods I've ever done to my car. I used Energy Suspension links, brackets etc. No issues and it's been 15+ years.
Old 04-11-2023, 12:09 PM
gtobird's Avatar
Did you go with the greaseable energy supension bushings that have the zerk fittings on the brackets or not? I think those are more of a recent invention, but maybe not.
Since you brought it up, I'm going to replace my gearbox eventually. What year gearbox did you use and were there any issues with the stops? I've got a 76 TA box laying around that I was thinking about using but other folks have said it's better to just have the original rebuilt to a better ratio.
Thanks for the input
Old 04-12-2023, 05:00 PM
400 Lemans's Avatar
Old Joe
It was just sway bar bushings and not body bushings. Ordered the front 1 1/4 kit with poly bushings from Ames and then got the rubber bushings from them later also.
Old 04-13-2023, 10:40 AM
My sway bar bushing brackets do have the zerk. My steering box and sway bar are from a 1978 model T/A. I had the box rebuilt by a place named Power Steering Services. (I believe since closed). They took the Firebird stops out as part of whatever they did. Talk to whomever is going to rebuild your box and I'm sure they can coach you. If your original box can be updated to whatever ratio suits you, I'd consider that.
