Old 04-10-2023, 05:04 PM
Dick Boneske's Avatar
Default Need Power Tapping Device
I have the need to tap several thousand wing nuts with 1/4-20 threads.
I can do it with a reversible cordless drill, but reversing is cumbersome. I have a DeWalt power screwdriver that reverses by twisting the handle, but it does not have enough power to drive the 1/4-20 tap.
I also have an industrial Delta Drill Press, but the Tap-A-Matic tapping heads are well over $500.
Anyone have suggestions?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 04-10-2023, 05:16 PM
Pav8427 Pav8427 is offline
Wire in a foot pedal on your drill press with a forward and reverse. We have one at work we use all the time for just what you are doing. Up to 5/8 taps.
Old 04-11-2023, 06:06 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
We have a reversing tap head at work. Works great. I did a quick search. Found similar for descent price.
https://www.amazon.com/Accusize-Indu...a-836276205771
Old 04-11-2023, 07:28 AM
JSchmitz's Avatar
We have a reversing switch on our drill press also. I used it to power tap. It takes a little more finesse.
Old 04-11-2023, 07:59 AM
Big plus is to add 2. One forward one reverse for when you need to tap LH threads.
Old 04-13-2023, 08:52 PM
Pontiac Performance Author
Get the reversing tap head. It has a clutch mechanism that allows a soft start and soft removal. I used one for years at H-O. I think mine was branded "TapMatic"
Old 04-13-2023, 09:15 PM
Stuart's Avatar
Stuart Stuart is offline
He's looking for something less expensive than the Tapmatic, since they're in the $500 range. I found a similar product (although I'm guessing it's made off shore) for $279, still not cheap but it may be worth it: https://www.amazon.com/Accusize-Indu...df_B00PWCXRVA/
