Old 03-18-2023, 06:25 PM
ejw's Avatar
ejw ejw is offline
Default Caltrac rear mount measurement
Quick question, anyone running caltracs can you please give me measurement on rear mount - bar bolt hole distance from flat part of plate. Basically how far down is rear hole
Thanks Eric
Old 03-19-2023, 10:24 AM
mysticmissle's Avatar
i have a set of moroso slide a links i can measure if that would help
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 03-19-2023, 11:22 AM
ejw's Avatar
ejw ejw is offline
Sure thanks
Old 03-19-2023, 02:17 PM
ta man ta man is offline
I can measure mine
Old 03-19-2023, 02:42 PM
Steve C. Steve C. is offline
On mine the centerline of the hole is about 3-1/4" to the bottom of the plate.
My set are quite old.
https://calvertracing.com/product/mt-2-mount/
Information on line states the distance should be enough so that the rod should be able to miss the springs by at least 1".
If it doesn't, these lower brackets will need to be a little longer.
Old information here:
Old 03-19-2023, 03:34 PM
ejw's Avatar
ejw ejw is offline
Thanks for info
