Old 02-11-2023, 05:24 PM
gomickeygo gomickeygo is offline
Default Cam help identify
I have this cam and lost the card. trying to figure out what this number bring up
Old 02-11-2023, 05:44 PM
Stan Weiss's Avatar
My guess would be that it is these Comp Cams lobes.
Stan
Pontiac Pump Gas List
Old 02-11-2023, 05:47 PM
Steve C. Steve C. is offline
Ground with a 110 LSA
Also note the cam was ordered with a "B" suffix code after the lobe numbers. In this case the seat duration (advertised) could be, but not always, altered by one or two degrees less duration.
Also the lobe lift might have 0.001" additional lift.
Old information here:
Old 02-11-2023, 07:10 PM
1968GTO421's Avatar
Stan
Looks like you have a stout cam
GTOAA--https://www.gtoaa.org/
Old 02-13-2023, 02:17 AM
Default Cam
Thanks guys... I figured something like that but not sure.... Maybe a good fit for a 535
Old 02-13-2023, 01:02 PM
Stan Weiss's Avatar
It comes down to the application. I could see running that in a hot street / strip 505.
Stan
