Old 01-29-2023, 09:20 PM
Mr Dave's Avatar
Mr Dave Mr Dave is offline
Default 70 GTO Bumper to Fender Gap
Fitting the front bumper on my 70 LeMans with a GTO bumper and fenders. Should the bumper touch the front of the fenders or should there be a gap? I'm thinking about what happens as the temperatures change and the endura expands and contracts. Thanks for the help.
70 LeMans Sport
95 Corvette
07 F350 Crew Cab 4x4
Old 01-30-2023, 08:38 AM
400 4spd.'s Avatar
You don't want them to touch. Because the bumper floats in front of the fenders (bolted to your flexing chassis), simply driving your car would cause the painted surfaces to rub.
Here is how I gapped a fellow member's car that we are completing.
Old 01-30-2023, 09:46 AM
Mr Dave's Avatar
Thanks for the reply! How much space did you leave? 1/8"?
Old 01-30-2023, 05:57 PM
400 4spd.'s Avatar
Probably closer to 3/16".
Old 02-01-2023, 04:58 PM
scott70's Avatar
scott70 scott70 is offline
I dont know what they did originally from the factory but I set mine as almost touching with no problems and looks better. I do understand them moving slightly around from each other,,just jack the front end off the ground by the cross member and watch the fender and nose height change from each other,,,off the ground they seperate and back on the ground is the tightest.. I wouldnt even do 1/8th "..
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 02-01-2023, 06:06 PM
dataway's Avatar
dataway dataway is offline
I think every car is a bit different as to how much clearance they will tolerate. Depends on about a dozen different things, fender alignment, core support alignment, condition of support bushings, trueness of the bumper, squareness of the hood, cross member sag, etc.
Just make sure you do it last ... engine in, everything in, sitting on the ground.
I think the factory use pretty large clearances because they expected people to be jacking them up by the bumper ... in which case you need about 1/4" by the time the bumper, bumper mounts and frame horns stop flexing and you actually start lifting the car.
