Front Coil Spring Compressor?
Hey Guys,
What is a good Moderately priced coil spring compressor for tall front coil springs? Thanks, Craig |
I just did trick springs install with a piece of all thread and a steel plate on the bottom of my an arm . You have to remove the lower a arm and you run the all thread up they the bottom of the a arm and up thru the shock hole with a washer and nut , use a ratcheting wrench to tighten the nut on top of the shock hole until you can wiggle the a arm back up into the frame pockets , there is a video on you tube , also a floor jack will help you
If this is a one time deal, check with your local auto parts stores - many of them loan out compressors for free.
The Following User Says Thank You to Stuart For This Useful Post: | ||
Very Dangerous Job. Don't skimp.
After years i found the best coil compressor ever. OTC 7045B Do yourself a favor This thing works great. |
catch them on the right day too, and be surprised how cheap they would sell their used equipment man.... i miss those days... the days when you walked into the parts store the parts guy KNEW about cars/parts/advice now-a-days..... just...... well.... sucks that it seems like we lost things like this fond fond memories of the time i walked in to Bladwin Motion performance because i saw them in the back of Car Craft Magazine...... I salivated over their F body and H body isle of new parts........ |
ive used the one in this thread a bunch of times with excellent results, can buy it new or rent one for free from most auto parts stores. i posted how i do it & always use a chain for safety. it feels sketchy the first few times but is pretty straightforward & safe after youve done it a few times.
https://forums.maxperformanceinc.com...d.php?t=863783 |
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
Good technique for when the motor was out, forgot that’s how I did the c2 when I had its motor out. Sent from my iPhone using Tapatalk
77 T/A- poncho 400| T-10|3.23| I beams|Hyper flat top pistons|Kre heads|Scorpion rockers|Xr276 hydro roller|Rpm intake|Smi qjet|Subframe connectors|Rancho sways|Mcleod super street|hydro clutch|More i cant remember |
Tall "18 drag springs with engine in and limited movement of lower control arm and bolt removal due to "2 headers
