Old 01-01-2023, 12:27 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is online now
Default 69 GTO parking light plug
Any leads on where to find the plug / socket / pigtail (whatever you want to call it) for the 69 GTO parking lamp? Car came with these sockets cut off the light wiring harness on both sides (driver and passenger)
Picture attached appears to be the correct layout… 2 flat pins at an angle and 1 round pin
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 01-01-2023, 02:05 AM
Scott Thelander's Avatar
So
Of course I just got home from the garage 40 minutes away and I’m sitting in the driveway at home reading the forum b4 I go in and deal with the noise
So you need a 3 wire and a 4 wire plug
I Assume
I may /should-have them I may go back down
Tomorrow
Grand Prix uses the same. Not reproduced
Scott
Old 01-01-2023, 10:00 AM
I read elsewhere about the two sides (driver and passenger) having different number of wires, seems odd. Any knowledge why?
Thanks for the tip on GP plugs being the same.
Matt
70 GTO 400 4-speed
Old 01-01-2023, 01:36 PM
25stevem's Avatar
25stevem 25stevem is offline
In looking at my schematic for a 69 both lamps are 3 wire .
The bulb used has two filaments, so a 4th wire can not be of any possible use because all you need are 2 hot feeds and a ground.
Bulb sockets with flat female spades are for the headlights, the marker lamp sockets for 1157 type builds have two round head pins.
I do stuff for reasons.
