I snagged the rear quarter windows out of the shed today to clean them up and get ready to install into my '66 post coupe. When looking at them, I noticed that the forward metal strips on each window are misaligned with the glass edges and also positioned at different heights.
Are the metal parts supposed to be positioned so they line up evenly with the edge of the glass? If so, any tips for removing and reinstalling them? ![]()
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
Did you get your car together ,and drive it this summer/ fall ?
Just checked my Tempest, they're both flush with the top.
FWIW, hardtop quarter glass also uses a piece of brightwork https://forums.maxperformanceinc.com...d.php?t=784341 |
Ha! No... That timeline was wishful thinking on my part. It's taking me a while to get through all the fiddly little things. I am still working on it every week though, and it's running, driving, steering, and stopping now. I was able to take it for a low-speed drive around the block about a month ago, just fast enough to confirm that the trans would go into all gears. Engine & trans work great, and there are ZERO leaks anywhere (a feat I'm rather proud of
![]() Quote:
One of the issues I was facing with this task is that my rear quarter windows never worked correctly before I took the car apart, so I never knew how they were supposed to attach to the forward channel of the body or articulate when rolling them down. They just kinda fell into the body before, so I always left them rolled up. Now that I am putting everything back together, I realize that plastic guide is suppose to slot into the forward channel and the glass is supposed to pivot from that plastic guide at the top as you roll the window down. By design, it seems like that puts a lot of strain on the plastic guides, so I probably won't want to risk breaking them by using the rear windows when the car is all back together anyway.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 01-01-2023 at 01:03 PM. |
Have you tried to "tap" them lightly to see if they'll move? I had to reattach one of mine and I used some kind of epoxy. Of course I don't sit in the back and don't roll those windows down, but they definitely do work properly.
I've not tried to remove them yet because I wasn't sure whether the factory glued them and I didn't want to risk breaking them. But it sounds like they are just press-fit onto the glass, so I'll remove & reposition them once I get the rubber from Ames.
Since they seem to have moved already(on their own?) I would try to move them before removing them.
I had that same problem with my rear glass. I held the glass wrapped in a towel and tapped on the end of the metal with a plastic hammer till it moved back in place.
