Old 12-27-2022, 11:15 AM
FinGTO FinGTO is offline
Default Tremec TKX shifter for a 69 GTO with a console
Hi,
I’m planning to update my Muncie M20 with a Tremec TKX.
More or less the only open question is the shifter.
I’f I have understood correctly, the the stock Tremec shifter does not fit with a console, but I need an offset shifter.
What are the Tremec TKX shifters options for a 69 GTO with a console?
Many thanks and best regards,
Samu
Old 12-27-2022, 11:33 AM
I measured and ordered an offset cut from a laser cutter. The shifter "pin" was cut, and the offset placed and welded.
Works well. I used a stock Hurst handle.
Pix if desired.
Old 12-27-2022, 11:42 AM
TB1's Avatar
TB1 TB1 is offline
Hello, I have this shifter for sale here, https://forums.maxperformanceinc.com...d.php?t=863076 . its for a 64-67 GTO the offset measurement is the same but the back is .150" longer which may or may not be a show stopper? I can get you better pictures if you'd like new offset pieces can be purchased as well
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
Old 12-27-2022, 02:14 PM
65madgoat's Avatar
Every retailer of TKX trans has shifters that will work perfectly with a console and no mods.
Call Silver Sport or American Powertrain
The Following User Says Thank You to 65madgoat For This Useful Post:
Old 12-28-2022, 11:19 AM
Formulajones's Avatar
MadGoat is correct, all the suppliers have their own brand of shifter that work with and without consoles for various car applications.
I prefer the White Lightening from American Powertrain. Comes in numerous offsets for many types of consoles, including A-body Pontiac, and then the shifter can be tweaked/adjusted in numerous combinations to suit a drivers liking. Also has reverse lockout when coming out of 5th gear which is really nice.
Shop around, prices vary quite a bit.
https://youtu.be/XqEydRRRwqE
Old 12-28-2022, 12:51 PM
65madgoat's Avatar
I second the White Lightning shifter.
But some swear by this QWIK STIK OFFSET SHIFTER:
https://www.ebay.com/itm/114939303100
Old 12-28-2022, 03:13 PM
Many thanks for the replies.
There seems to be a wide range of offset shifter options available.
In one end of the spectrum, an offset shifter is just a customized external base bar (@scarebird could you please show some pix of your solution).
And in the other end, it is an internal customized shifter that even isn’t necessarily a bolt on part (like the STX shifter https://shiftsst.com/blog/post/gm-a-body-1968-1972.html).
Anway, what I am looking for is a bolt on shifter (and be able to buy just a transmission instead of a +$1500 package).
Old 12-28-2022, 03:27 PM
65madgoat's Avatar
A custom shifter is about $300 more....
Old 12-28-2022, 03:39 PM
as you requested...
Finished item. I can send you the drawing if desired.
Old 12-28-2022, 03:42 PM
Note I had to cut the pin in half and press off the bushings before welding so they would not melt - then press them back on again.
Old 12-28-2022, 03:50 PM
And it is a bolt on?
Old 12-28-2022, 03:57 PM
as you requested...
The pic is missing?
Old 12-28-2022, 04:14 PM
70GS455 70GS455 is offline
The one you want to ensure no cutting and to get the drive line angles correct will be one where the shift turret or tower is offset to the side, and is centered in the console opening. They do not look like a bolt on option, except at the vendor facility.
Sent from my SM-S901U using Tapatalk
Old 12-28-2022, 04:17 PM
as you requested...
I can’t see the pic, there seems to be some issue with the link/attachment.
Old 12-28-2022, 04:36 PM
2nd try
Name:	Shifter offset.jpg
ID:	604187   Click image for larger version
Old 12-28-2022, 04:38 PM
Many thanks!
Old 12-28-2022, 04:50 PM
gman005's Avatar
gman005 gman005 is offline
I put a white lighting in my 72.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 12-28-2022, 11:24 PM
Old 12-28-2022, 11:53 PM
Maybe this will help. Yes it's a bolt in. Hit the option menu for a drop down.
These are sold with different offsets for all kinds of applications. The 2.25" offset is typically what is used in a 68-72 A body Pontiac application with a console.
You could call to confirm but pretty confident that's what I've used in the past
https://americanpowertrain.com/shop/...ec-tkx-5-speed
