Old 11-26-2022, 08:40 PM
grd777 grd777 is offline
Default need some tips on fender alignment
tried everything but i cant this any better , any tips
Name:	IMG_7379 (002).jpg
ID:	602644   Click image for larger version
Name:	IMG_7381 (002).jpg
ID:	602645   Click image for larger version
Name:	IMG_7380 (002).jpg
Old 11-26-2022, 08:57 PM
Formulabruce's Avatar
That door a 72? I have seen, and I set these up in the later 70's and early 80's , wide gaps like that from the factory. There needs to be enough gap in the middle to shut the door at the style line area or the fender has to come out some. You can run a bead of weld on the door or fender and re radius it. Some folks get it down to metal and use short strand fiberglass ( "bondo") to do this. If not close to hitting, this will last if prepped and mixed right.
At Sema shows, the "Riddler" Award cars 99% of the time have perfect gaps and they are made from filler where needed. yeah I said that, and its 100% true. Can show videos to you if needed.
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 11-26-2022, 09:00 PM
it is a 72 is a very big gap at the top of the fender to the door every where else it fits good the driver side is very good
Old 11-26-2022, 09:06 PM
694.1 694.1 is offline
Looks like factory gaps to me! To improve takes welding & grinding.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 11-26-2022, 09:18 PM
i will take a photo of the drivers side so we can compare
Old 11-26-2022, 10:26 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
Not being there and only 3 pics makes it a little tough. How many shims are on the cowl to fender bolt in the upper door jam? How many shims are on the front of the firewall? Judging by the size of the upper lip, it looks like a GM fender, correct?
Just for kicks I attached these gaps on my brand new '71 Camaro. Not perfect by todays standards, but shows how the got parts to fit quickly. Next pics are how I repair gaps especially with repop panels. I weld welding rod to one side, grind it flush, and use lead to fill it. I would avoid any type of plastic filler on the edge of jams. This would be the very last resort for you. Need to figure out the simple stuff first.
Name:	71 Camaro lf 2.jpg
ID:	602658   Click image for larger version
Name:	71 Camaro lf 3.jpg
ID:	602660   Click image for larger version
ID:	602663   Click image for larger version
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
Old 11-26-2022, 10:32 PM
great photos . i will take a look at the shims , your gap on the camaro are much better than my photo, do u know how i can rotate my photo
Old 11-26-2022, 10:49 PM
HoovDaddy's Avatar
Hold the phone sideways. The long side of the photo needs to be top and bottom.
Old 11-26-2022, 10:54 PM
here is a untouched car much better gaps
Name:	IMG_5481 (002).jpg
Old 11-26-2022, 11:26 PM
ID67goat's Avatar
ID67goat ID67goat is offline
Are you aligning the fenders with the weight of the car on all 4 tires on the ground? If on jack stands the subframe could sag and make the gap larger at the top.
Make sure to align doors to body, align fenders to doors, and then shim the core support to the fender.
The Following 2 Users Say Thank You to ID67goat For This Useful Post:
Old 11-26-2022, 11:33 PM
yes i had the car on all 4,s spend hours trying to get the gap better at the top. i guess i will keep tiring
Old 11-27-2022, 09:30 PM
JUDGE3 JUDGE3 is offline
On all my gaps I welded a small bead, then used micro fiber fiberglass filler to fill the weld and smooth and blend as needed.
had the exact same gap in your pics also.
like seein the pics of original new gap and door alignment. I have learned to work them to what I will be satisfied with instead of trying to duplicate experienced professionals.
Old 11-28-2022, 03:21 PM
jhein's Avatar
jhein jhein is offline
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 11-28-2022, 03:27 PM
you are a great guy ,thanks for this . i think this gap is way to big ,the driver side is way better . not sure what to do next to fix it
The Following User Says Thank You to grd777 For This Useful Post:
Old 11-28-2022, 05:38 PM
HoovDaddy's Avatar
Are there any shims on the bolt that goes into the firewall below the hood hinge?
How much gap between the quarter and door?
Which of these parts are original to the car and which ones have you installed?
Old 11-28-2022, 07:52 PM
if i remember correctly, there is a few shims in the firewall ,the gap is good below the gap on the door and the hood and fender are oem that i installed
Old 11-28-2022, 08:45 PM
HoovDaddy's Avatar
If there are shims on the bolt I'm talking about, the shims are moving the fender forward. Please verify, or take a pic. Also that fender mounting tab needs to be 90 degrees. If it's bent it will compound the problem. Let me know, then we can move forward, or backward. lol
Old 11-28-2022, 08:54 PM
ok will do thank you for helping me .i will be going to me shop soon and take photos
Old 11-30-2022, 02:50 PM
dld's Avatar
dld dld is offline
you can close that gap at the top buy lifting the core support .
the gap down the door is largely controlled buy the location of core support . tip don't bolt the front of fender until last
first align door to quarter and rocker . then align the fender to the door . you can budge center or flatten it buy the shimming the bottom of fender.
the fender should be a little out further then the door for clearance and air into the jam
Old 11-30-2022, 06:03 PM
thanks a lot ,this is great info i will try this on the weekend
