73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 11-17-2022, 05:31 PM
TOPHER TOPHER is offline
Default need help measuring length of trunk weatherstrip for 73-77 A body (LeMans, etc)
I'm trying to solve a riddle. Can someone measure from point A to point A the length of the weatherstrip channel, I just need to know how long the weatherstrip would be. Thanks Super Friends!
Old 11-18-2022, 06:41 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
I don't have a measurement, but you can arrive at the number with a piece of string if you lay it out in the channel. Also, IIRC the weatherstripping tends to come long and gets cut by the installer to ensure a perfect fit.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well.
>>My 73 Build thread
Old 11-19-2022, 03:07 PM
David Brown's Avatar
David Brown David Brown is offline
Send a message via ICQ to David Brown
Why do you want to measure. They always send a little too much. Find the middle of the strip and start it in the middle of the trunk lip, by the back wondow. Insert it in the lip, all the way around on both sides being careful not to pull it (stretch). The two ends will meet in the middle by the bumper. With a sharp razor, cut both ends and cement the two ends together.
