Old 11-07-2022, 06:54 PM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
Default Supercharger and Distributor Clearance
What's the largest Supercharger you've seen with the distributor in the stock location? 8/71? 10/71? 14/71?
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
Old 11-07-2022, 08:27 PM
Tom Vaught's Avatar
Boost Engineer
I believe George was able to package a 8/71 supercharger as was twooldgoats but that is purely an assumption.
Ask T O Gs
Tom V.
Old 11-07-2022, 09:36 PM
Scott Roberts Scott Roberts is offline
Why not offset it or run it off the front? Limited on room?
Old 11-07-2022, 11:52 PM
I was looking at running a belt drive and running the distributor in front but I'm concerned about the blower belt and pulley being in the way. Anyone ever mock something like that up?
Randy Repp
Old 11-07-2022, 11:54 PM
Ask T O Gs
Tom V.
I know I can run an 8/71. Dill and GTO George do but CAN I go bigger? That's really the goal.
Randy Repp
Old 11-08-2022, 12:15 AM
Tom Vaught's Avatar
Boost Engineer
Talk to Probird, He runs a large 5 liter per revolution Whipple Supercharger and might be able to help you out.
Tom V.
Old 11-08-2022, 12:29 AM
I ran a moon cover with a front drive for my mag and fuel pump.. it did extend beyond the belt but you have plenty of room between the belt for a belt driven distributor.. the idler pull spreads things out pretty good..
Never ran the set up ur after but can't see where the belt would interfere al all..
Why not run a mag over a distributor?
Old 11-08-2022, 01:16 AM
chiefbigb chiefbigb is offline
I ran a 8/71 with BDS manifold. Small diameter msd cap will fit.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
Old 11-08-2022, 01:46 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
If a person were to use a crank-triggered ignition, an original distributor could be "chopped & sectioned", since all it would need to do would be to distribute the spark to the plugs- it would easily fit under the rear of even a 14-71! [14-71 mounting is identical to 6-71, etc.]
The Following User Says Thank You to Jack Gifford For This Useful Post:
Old 11-08-2022, 01:54 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Exactly! I run a 10-71 blower with a modified Wenzler Gutsram and a crank trigger and the distributor (unchopped) fits under the blower. With a shorter intake, the distributor could be cut down to fit. A lot of these issues are covered in the thread about my supercharger build:
https://forums.maxperformanceinc.com...n+alky+tempest
Jim
Name:	dist location.jpg
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
