Old 09-16-2022, 04:10 PM
79firebird_99TA's Avatar
79firebird_99TA 79firebird_99TA is offline
Default Recommendations for gear reduction starter
Hi. Been a while since I've been here. I've not driven the Firebird in over a year and a half. I'm wanting to change the starter from a stock full size to a gear reduction. I have Hedman headers. Can anyone recommend a good starter?
79 Firebird/`70 400 with `77 6x-4s shaved .065"/4 speed BW ST-10/Cliff Q-Jet/XE268/3.08
99 Trans Am/383 LS1/TSP headers and catback/custom grind cam/Vigilante 2500/Strano springs and Konis
08 Corvette - Base
(SOLD) 75 Corvette/L48 350 (LSx -4L60E one day)
Old 09-16-2022, 04:28 PM
I'm thinking about the Powermaster Ultra Torque 9410NM. Any opinions?
08 Corvette - Base
Old 09-16-2022, 05:15 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I have a Tildon om the 78 for years. I did have to reclock solenoid-which required drilling and tapping new holes. A McRobb on the Camaro/IA which is easy to clock.
Skip Fix
Old 09-16-2022, 05:38 PM
ZeGermanHam's Avatar
Powermaster 9510 is the one to get.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 09-16-2022, 06:09 PM
jhein's Avatar
jhein jhein is offline
+1 on the Powermaster 9510
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 09-16-2022, 06:11 PM
I worry about that gear, hanging out in the wind, without support.
Bill Nye.
Old 09-16-2022, 06:24 PM
The 9510 on my brother's 461ci has been working flawlessly for years. No issues and it totally transformed how well his car starts, particularly when hot.
Old 09-16-2022, 06:29 PM
9510 it is!
Thanks.
08 Corvette - Base
Old 09-20-2022, 12:54 AM
Formula8's Avatar
Formula8 Formula8 is offline
RobbMc: https://www.robbmcperformance.com/pr...c_starter.html
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 09-20-2022, 01:57 AM
wakesupremo wakesupremo is offline
I have the MSD unit on mine. Been spot on for years. No issues at all.
Old 09-20-2022, 07:27 AM
Formulajones's Avatar
I prefer the Robbmc with the gear support. Only mini for Pontiac that offers it that I'm aware of.
Plus his customer support is excellent. He has warrantied stuff that he didn't have to, and has had quick turn around even today with all the excuses everyone else uses.
There are quirks about these mini starters in general I don't care for but I deal with that no matter what the brand.
https://youtu.be/XqEydRRRwqE
Old 09-20-2022, 10:37 AM
track73 track73 is offline
Everything Formulajones has said, Robbmc for me.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
Old 09-20-2022, 10:40 AM
racegto65's Avatar
racegto65 racegto65 is offline
I use this one.
https://www.summitracing.com/parts/csi-102p
Old 09-20-2022, 01:20 PM
srmmmm's Avatar
srmmmm srmmmm is offline
I used this one from Summit:
https://www.summitracing.com/parts/s...s-am/year/1970
Customer reviews were good on it and it performed well when the engine went on the dyno for break in and tuning.
Old 09-21-2022, 09:57 PM
P@blo's Avatar
P@blo P@blo is offline
Powermaster 9510 15 years working great and good customer service.
Old 09-22-2022, 01:47 AM
64speed's Avatar
64speed 64speed is offline
ROBBMC
The Following User Says Thank You to 64speed For This Useful Post:
Old 09-22-2022, 05:19 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Running the 9410 for 4 years now, still spins like new. It’s rated 50ft.lbs higher than the 9510 XS and is about $50 more. A Summit mini struggled and I had issues with the pinion gear coming loose on a RobbMc.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 09-22-2022, 07:26 AM
The pinion gear coming loose is a real problem on all of them.
When dad was running the other mini starter mentioned in this thread, the snap ring would come off eventually. The big problem with that is those starters don't have pinion support. So the gear goes flying off. If you're lucky like he was that day, you find it laying in the grass, slide it back on for another restart and drive it straight home. If your not so lucky to find the gear you're calling a hook.
At least with the Robbmc and the pinion support the gear stays on the shaft and doesn't go anywhere. In fact he drove it a few months like that before fixing it. Yes the Robbmc starters lose the gear too. Retention is with a small ball bearing and lock tight. We've had the gear come loose twice on a Robbmc. Neither time left us stranded as with the nose support it doesn't fall off and both times robb fixed it for free when the starter was several years old so I can't complain. Great service.
That's just one of the quirks with these mini starters you have to deal with. At least with the nose support I don't worry about being stranded next time it happens. There will be a next time lol
Old 09-22-2022, 10:29 AM
carcrazy carcrazy is offline
Used RobbMc for years without issue on a high compression,. 600+ hp 461.
Old 09-22-2022, 12:06 PM
rohrt rohrt is offline
This is funny to me.
I was looking at the price
https://www.amazon.com/Powermaster-9.../dp/B003TQ6A4W
I can see a crack in the casting.
