Old 09-16-2022, 10:28 AM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Default Tool to elongate pushrod holes in heads?
I remember a while back someone was making a jig to elongate pushrod holes to clear 1.65 rockers. I thought it was Spotts Performance but their web site doesn't show any. I E-mailed them but they do not reply. Does anyone know of such a tool and where to get one?
Old 09-16-2022, 11:25 AM
PAUL K's Avatar
PAUL K PAUL K is online now
It was Spotts. As of late he has become diffucult to communicate with. We use a 3/8 ball shaped carbide burr.
Go fast, see Elvis!
Old 09-16-2022, 11:53 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Like Paul said Paul Spotts had one. After thinking I had ground enough on one that after assmebly was tight in the middle I bought one. It takes a fair amount off all the way to the bottom of the hole! Using it and a mill would be the best . Using a hand drill it was a little hard to keep straight and not enlarge the guide.
Skip Fix
Old 09-16-2022, 12:08 PM
Thanks for the replies. Spotts E-mailed back. Said he was out of stock and will have some more some time this winter.
Old 09-16-2022, 12:27 PM
25stevem's Avatar
25stevem 25stevem is offline
If you can get your hands on a big enough drill to power a 1/2” bit then just simply drill out each hole and then use a carbide burr to taper out the rocker stud side of the hole down to a depth of 3/4”.
You will not have to take much off once each hole is opened up to 1/2” inch.
I do stuff for reasons.
Old 09-16-2022, 08:56 PM
slowbird's Avatar
slowbird slowbird is offline
I have one, pm me if interested
ID:	598788   Click image for larger version
ID:	598789   Click image for larger version
Old 09-17-2022, 08:13 AM
Half-Inch Stud's Avatar
I remember Paul saying he wanted to call it the "Spott-Eye" pushrod hole oval grinder for 1.65 rockers.
I complemented him that he has always been about proper fixturing, whereas i would just "get it done" by dinnertime.
Old 01-24-2024, 09:05 PM
blueghoast's Avatar
Smile
So how does it bolt down and to what?
GT
Old 01-24-2024, 11:32 PM
ta man ta man is offline
Rat tail file works great to finish
Old 01-25-2024, 11:35 AM
Formulas Formulas is offline
GT
Bolts down on rocker stud boss, instead of the stud
Old 01-25-2024, 11:41 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
The last couple of motors I put together, while mocking it up I used a straw slit along its length and put it around a push rod and used it as a feeler gauge to check for any tight spots. A sharpie line along the straw helps.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
Thread Tools
Display Modes
