Old 12-09-2022, 06:19 PM
rbrtmchl's Avatar
rbrtmchl rbrtmchl is offline
Default Part Identification Help
Can someone give me an idea as to what this part is, and where it is supposed to be located? Car is a 1974 Formula 455.
ID:	603315   Click image for larger version
Bob
1974 Formula 455 - Ascot Silver
Old 12-09-2022, 09:49 PM
This is off the top of my head, maybe for the seat belt interlock thingy on the fenderwell?
(I'd have to look at my info for sure)
Don't remember anything like that though.
Old 12-09-2022, 10:00 PM
Trevor78 Trevor78 is offline
What does the tag say?
Old 12-09-2022, 11:10 PM
rbrtmchl's Avatar
Thank you for the replies.
You might be right. This part and connector are located in the vicinity of the '74 only seatbelt interlock override. The interlock system was defeated at some point in this car's past, like many other '74s I am sure.
The tag says:
MITO CORP. 50-5170GTEMP
GENTEX TEMP HARNESS
C&G 5/12/04
I believe that this tag identifies the protective sleeve over the two green wires.
Anyone have any more information that they can share?
Bob
Old 12-09-2022, 11:53 PM
Does it have a fancy rear view mirror or similar with digital temperature readings on it, or perhaps similar gauges for ambient air temp, engine temp, AC etc?
Old 12-10-2022, 12:19 AM
rbrtmchl's Avatar
As a matter of fact, the previous owner installed a Mito Mirror some years ago. I think you have very likely solved the mystery. I'm currently working on a radio project under the dash. I will see if I can find these wires and if they route up to the mirror. Thank you very much!
Bob
Old 12-10-2022, 03:49 PM
rbrtmchl's Avatar
Just to close this out, the part in question is the ambient temperature sensor for the Mito Gentex mirror. I found this picture online. Also, I traced the wires. They are routed to the installed mirror. Thanks to all who replied.
Name:	Mito Gentex Mirror Accessories.jpg
Bob
The Following User Says Thank You to rbrtmchl For This Useful Post:
Old 12-11-2022, 12:40 PM
jerry455 jerry455 is offline
I added the same mirror and sensor to my 1976 Firebird. I routed my sensor to the top of the grille to get a good outside temperature reading.
Old 12-11-2022, 10:54 PM
rbrtmchl's Avatar
That's a good idea, thanks. That has to be better than dangling loosely down by the firewall. That's where I found mine.
Bob
