Old 09-09-2022, 01:11 PM
imposter's Avatar
imposter imposter is offline
Default QA1 Suspension
i was looking into this kit QA1-HK02GMB2 for a 66 bonneville 4 door, are the frames the same as a 66 chevy impala they have no listing for pontiacs
https://www.summitracing.com/parts/QA1-HK02GMB2
Thanks for reaching out. The kit you listed is for Chevy full-size models (Impala, Caprice, Belair and Biscayne) models only. GM did not communize their full-size chassis until 1971. This kit will differ from your specific set up and will not bolt in as designed. We currently do not have a specific handling kit or individual items for your Bonneville at this time.
Thanks again for your question, I have noted your request for ’66 Bonneville parts for future consideration in adding to our lineup.
If you have any other questions please let us know.
Thank you,
Old 09-09-2022, 02:22 PM
webfoot's Avatar
webfoot webfoot is offline
yeah its not the same.
Look up front/rear shocks for your application. Then see if it cross-references to any (for lack of a better term) more popularly hot-rodded car for which coilovers may exist.
For example, I found my 62 catalina used the same shocks as a 78 F-body so I got QA1 front coilovers for that year and they almost bolted right in, all I had to do was drill out the captured nuts in the lower A-arm.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
Old 09-09-2022, 07:19 PM
imposter's Avatar
wondering whats different the front control arms list as the same along with the rear sway bar
Old 09-09-2022, 10:03 PM
Mario64's Avatar
Mario64 Mario64 is offline
I know you asked about qa 1. Here is a link to aldan for your car.
https://aldanamerican.com/year-make-...position=front
Mario64
Old 09-09-2022, 11:31 PM
Stuart's Avatar
Stuart Stuart is offline
The chassis and suspension on a 1966 Chevy was totally different from a 1966 Pontiac. There might be the odd nut or bolt that was used on both but that would be it.
Old 09-11-2022, 03:45 PM
389 389 is offline
Pontiac did major upgrading on their 1965 up B body cars. They raised KPI which really gave these cars excellent handling ability. You don't need a lot of positive caster with these cars, 2 maybe 3 degrees of positive caster is all that's needed. Keep the camber under 1/2 a degree and use camber to remove unwanted right side drift.
-Have Delrin bearings installed into your stock upper and lower front control arms.
-Use Bilstein shocks find out which ones by size instead of model of car.
-Call Lee suspensions and get one of their 800 series steering boxes with a 25- or 30-pound torsion bar.
-Get some Currie Johnny joints and some 2" pipe and make a nice set of rear control arms. Use there weld in bungs.
-Do Not Use Poly bushings and Do Not box rear control arms on street driven cars.
-In 65, Pontiac put some big drum brakes on their B body cars. I would keep them. Keep the 8 lugs, if you have them. There better then front disc rear drum brakes providing you know how to adjust the anchor pins and brake shoes, don't depend on self-adjusters.
Franks Pontiac parts is the only place that has 8 lug drums without any corrosion.
Old 09-11-2022, 11:41 PM
imposter's Avatar
sounds good where do i get those
