Old 07-27-2022, 10:45 AM
1oldgoat's Avatar
1oldgoat 1oldgoat is offline
Default Parts to Norwalk
I will be bringing the following parts to the Ames Performance Tri Power Pontiac Nationals at Norwalk, Ohio August 12-14. There are many NOS parts, as well as used parts. I think I have priced everything but am open to offers on many items. I will be setup in spaces 118, 119, and 120 with a black 24’ enclosed trailer and lots of tables and pop-up tents. These parts are already packed, loaded and ready to head to Norwalk. Sorry for the long post but there are a lot parts.
NOS Parts
68-72 GTO windshield molding set, top 7226034, right side 7225635 and left side 7225634 $450/set
68-72 GTO windshield side moldings 7726034 and 7726035 $150 each
64-70 Accessory block header cable 984642 $100
70 GTO fender marker lamps 916015, 916016 $650 pair
67-72 A, G, B power trunk release accessory kit 984812$450
68-72 convertible courtesy lamp lenses 4482877 $25 each
67-69 battery hold down clamps 6270159 $15 each
67 Firebird 400 AC 40490 rebuilt fuel pumps $200 each
68 GTO outer door window fuzzies/weatherstrips RH/LH 7726811/7726810$475 pair
67-69 Firebird quarter window outer window fuzzy’s 7725934 7725935 $275/set
Ram Air III manual cam shaft 9785744 $750
71-72 GTO fuel sending unit 6428837 $350
71-72 GTO, Grand Prix, 71-75 Firebird LH remote sport mirror kit 989007$350
66-69 GTO, 69 GP 4-spd shifter adapter 9785269$125
67-70 Firebird front leaf spring bushings 3892753$100 pair
Late 68-69 Firebird std outside rearview mirror 3914753$175
67-68 Firebird wheel opening molding set, original wrappers gone, never installed $450
67-68 Firebird wheel opening moldings, both fronts, RR in original wrappers, $350
65-67 all, 68-69 Firebird power distribution block 3905263$40
67-69 Firebird battery tray 3893882 $175
68 Firebird turn signal lenses RH/LH 5960531/5960532$250
67-68 Firebird RH tail pipe hanger 3938904 $75
67-68 Firebird fender “bird” emblems, no box 9789589$95 pair
68 Firebird only horn relay/key buzzer 1115889$275
69 Firebird quarter marker lamp assembly, no chrome bezel, 911139$175 pair
68-69 Firebird LH washer nozzle 9792935 $95 each
70 Firebird, 71-73 all ignition switch 1990098 $50
68-73 Firebird, 69-72 GTO/GP headlight switch, w/o hideaways 1995154$65
73 Firebird manual trans neutral safety switch 3996277$50
70-72 Firebird manual trans neutral safety switch 3983965$50
67-69 lighter insert 7033244 $75 each
70 all, 71-72 A, F, G hood latch/lock 9722701 $350
67-81 F w/AT brake pedal stainless trim 3888683 $25 each
67 seat adjuster knob, chrome 7665300 $75
72 & up side post battery cable 55” 8907023 $125
58-70 under hood reel-out work lamp accessory kit 988948$450
64-65 lighter insert 5773973 $100 each
69-72 ashtray lid/bezel 8795489 $45 each
69-75 dome light lens, round w/ star pattern 8732777$25 each
67-77 chrome heater control knobs 7295955 $15 each
68-72 Air cleaner thermostatic valve, black w/circle AC 6484242$95 each
68-69 idle stop solenoid w/bracket w/6 cylinder. 1114420$150
71 455 HO choke thermostat coil 7041094 $275
15” Honeycomb trim rings (only have 2) 490771$300
15” Rally II trim rings 9796696 $750 set
14” x 6” Rally II trim rings 475019 $450 set
71 only Honeycomb center caps, set of 4 9791068 $650
72-76 Honeycomb center caps, set of 4 9795568 $475
71-72 Custom/Deluxe full wheel cover set 988726$350
67 Deluxe wheel cover, single (black center) 9710754 $75
301 Valley cover 527245 $125
69 Lemans/Tempest/Custom S turn signal lenses RH/LH 5961314/5961313 $75 pair
66-67 Lemans/Tempest turn signal lenses RH/LH 5957704/5957703 $75 pair
Headlight bucket “C” 5950513 $30 each
Headlight bucket “B” 5963889 $30 each
Headlight bucket 5948827 $30 each
Headlight bucket 5948826 $30 each
Headlight bucket 5955498 $30 each
66-67 GTO/Lemans/Tempest headlight bezel RH $125
72 GTO/T-41 Lemans turn signal lenses, dated 72 911880 $600 pair
69-72 Grand Prix SJ fender emblems 479202 $250 pair
67-68 Tempest fender emblem 9787902 $65
64-69 GTO trunk emblem 8701433 $45
68-70 GTO hood scoops 9791144/9791143 $300 pair
67 GTO/Lemans/Tempest carpet toe guard 3897543 $100
69-77? Tilt steering lever $25
69-75 dome light lens for cars with map light 8780507 $25
68 deluxe seat belt, rear 49 C 67 date $125
68-70 Rally Wheel, big car, ½”, black center lug nuts (3) $25
70-72 GTO fuel pump, AC #40863/40933 6470513 $250
68 GTO/Firebird 400 fuel pump AC #40607 6417212 $275
69 GTO/Firebird, GP w/4bbl fuel pump AC #40679 6417419$300
72 455 HO, 73-74 455 SD fuel pump AC #40931 6470670 $450
75-81 all windshield wiper motor assembly 4961608$125
66-77 all V8 oil fill cap “FC-2” non-chrome 850843$25 ea.
62-75 6cyl water pump “cast” impeller rotor 3873840 $25
69 Firebird pitman arm w/PS 7806617$225
77-81 A, B, F starter drive lever 801433 $10
64 A and B, 70-71 all w/rally gauges, temperature sending unit 1513321 $125
66-73 door jamb switch, stamped MB 9662504 $50 each
69 GTO under hood wiring harness 6297460 $500
70-73 Firebird/Trans Am headlight bezels RH/LH 483412/483413 $500
69-73 Firebird park lamp assembly 5960552 $350
70-73 park lamp fillers 483960and 483961 $650 pair
68 GTO dome light lens 7731128$50
68 A, 69 Lemans/Tempest side marker lens, rear 5960486$50
70-72 Rally II center cap medallions 480302 $125 set of 4
69 Firebird power steering pitman arm 7806617 $250
67-72 A212CW rare Square Mesh air filter element 6421746$150
71-74 All Pontiac V8, power steering pump “cast” pulley 493243$125
70-71 dog dish/poverty cap “Pontiac-Pontiac” style 5738083$100, only have one.
79 Trans Am power steering hose 7829913 $125
64-81 Brake hose/shift cable retainer clips 334961 $5 each
68 GTO/Lemans/Tempest air inlet valve for AC 3014079, goes behind RH kick panel, $125
66 Sprint 6 fuel pump AC 40508, 6416834 $150
67-69 Sprint 6 fuel pump AC 40528, 6416912 $150
67 GTO fuel pump, 1st design, AC 40521, 6416911$250
67 GTO fuel pump, 2nd design, AC 40610, 6417175$250
All years, center hump trash can, red $100
68 GTO Chrome exhaust tip accessory kit 984996 $350
64-72 all tissue dispenser accessory kit w/original unopened Kleenex box 981799 $150
70-71 tissue dispenser/trash can accessory kit 988761$150
67-69 Firebird upper windshield molding 7638868 $225
68 GTO/Lemans 4-speed back-up switch bracket $75
71-72 GTO/T-41 Lemans hood pin accessory kit 988942$325
73-74 Lemans/GP heater hose 495129 $10 each
71-72 GTO/Lemans coupe headliner, blue 495129 $150
65 GTO/Lemans RH quarter panel extension tail light housing 4470310 $175
64-67 GTO/Lemans. 67-70 Firebird, 71-72 GTO Lemans hood hinge springs 3848272 $85 pair
67-70 full-size power steering hose 7810143 $125
69 Grand Prix RH rear marker lens 9796816 $75
76-78 rag joint/steering coupler 7826542 $150
65 GTO/Lemans/Full size cast AC compressor bracket 9779015$50
70-72 Lemans/T-37/GT-37 400 rocker emblem 480197$100
70-75 Firebird/Trans Am AC blower speed switch 157432$45
57-72 RC-15 radiator cap, small ear cap 861050 $50
67-68 Firebird front license plate bracket 9788865$150
70 Lemans quarter panel emblem 8702945 $75
76-81 all w/1” front sway bar bushings 371773 $15 each
70 Firebird, 71-73 all w/o tilt ignition switch 1990084$50
71-74 Formula 455 fender emblems $150 pair
70 Firebird 400 emblem 480181 $75
67 Lemans/Tempest OHC-6 fender emblem 9787?06 $50
73-77 Firebird tire inflator 493790 $100
57 Axle bump stop 525219 $15
65-70 Full size transmission mount, all w/MT 479711$35 each
65-72 A, 70-74 F, w/7/8” sway bar bushings 388294$25 each
67 A, F hub cap center emblem, black w/red PMD 9778676$25
68 Lemans/Tempest headlight-grille hour-glass filler $50
67 Firebird turn signal lenses RH/LH 5960020/5960019$80 pair
68-72 air cleaner vacuum switch, black w/circle AC 6484242$100 each
71 455 HO temperature sensor W/O rally gauges 6490153$100
64-66 GTO/Lemans/Tempest LH steering arm 383807 $75
76-77 A, F Blower motor 22020943 $75
NOS AC PCV valves $10 each
70-71 GTO/Lemans/GP speed warning buzzer 478918 $125
68-72 A, 68-69 F; 69-72 G MT Shifter boot/seal 9795407$150 each
Reproduction and Aftermarket Parts
Speedmaster large journal 4-bolt main caps $200, new
OER 67-69 Firebird trunk weatherstrip $10, new
69 Firebird front suspension kit+ $125, new
67-69 Firebird Battery tray $15, new
67-68 Firebird rear brake hose, rare single crimp $75, new Wagner brand
68-69 GTO spring ring battery cables $75, new
1000’s of glass fuses, mostly Buss brand, new
Aluminum rods, Super-Rod brand, $250/set, new
4-speed shift knob, black $20, new
USED Parts
Vintage 14” Mickey Thompson Wheels 5 spoke wheels, narrow 14” fronts w/vintage tires, wider (7”-8”?) rears $850
lug wrench $20
push rod guide plates, std $40/set
67-68 Firebird front air dam, nice $500
alternator fans $5 each
misc. distributors $15 each
water crossover only, cut from aftermarket manifold $10
68 Ram Air I, black cap advance control vacuum valve $250
68 Ram Air II, green cap advance control vacuum valve $600
68-69, 71-72 GTO, 68-72 GP hood latch $100
67-68 Firebird base grilles $25 each
67-68 Firebird 400 grilles $150/pair
70-72 12-bolt, 3-series, posi unit $375
73-74 SD exhaust manifolds $400
71 400 manual trans carb 7041263 $1500
70 455 auto carb body only 7040268 $75
70 455 auto carb 7040268 $200
72 455 HO auto carb 7042270, 0645 date $3000
71 455 HO auto carb 7041270, 2222 date $3500
67 Ram Air/HO starter 1108353, rebuilt, 7D28 date $1250
Exhaust cross-over block off plates for 2-piece intakes $50 set
68-69 Firebird leaf spring/shock mount LH $35
68 Firebird burlwood radio trim, driver condition $25
68 Firebird RH turn signal lens $25
66 GTO Original front spiral shocks, no rust $150
Vacuum “T” angled $50
69 Grand Prix “beehive” wheel cover, good condition $50
72 Unitized distributor w/ cap and wires 1112127, 2A5 date $200
73 Unitized distributor, no cap, or wires 1112203, 3B7 date $100
70-72 Firebird AM/FM mono radio, rebuilt, no knobs 05/22/2022 $475
71-72 GP or GTO Chrome button “red dot” AM/FM stereo radio, untested, $400
70 A-body instrument cluster non-rally $35
70-72 GTO/GP rear boxed control arms w/new bushings $225
67-75 various used owner’s manuals $5 each
71-72 GTO/T-41 Lemans RH headlight bucket, good condition $275
68 GTO 4-speen hurst shifter $325
68-70 Hood tach, original, beautiful condition, untested $750
69-72 GTO chrome remote mirror, nice driver condition $125
69 Ram Air IV intake 9796614, 01-23-69 date, $1750
64 GTO 4-spoke, wood steering wheel, nice original condition, with all horn parts. $2250
70-71 GTO/GP dash tach $250 each
69-71 Rally Gauge cluster $300
68 Firebird Deluxe steering wheel core w/cap $200
78-81 Trans Am WS6 Wheels (3) $200
67-68 Firebird front bumper bracket LH $40
71 GTO Grill RH, good condition, painted black $100
67-68 Firebird fuel filler neck cover $10
72 Lemans grilles, nothing broken, good condition $150
4-blade fan $40
7-blade fans $50 each
14” honeycomb wheels, set of 4 $275
67-69 Firebird spoiler (Camaro style) $85
73-77 Trans Am air cleaner lid $45
71-72 GTO hood scoops $100 pair
71-72 Lemans head light bezels $40 for all 4
69-72 A-body carpet/toe guard $25
68-70 GTO LH hood scoop insert, non-Ram Air, $25
69 Lemans front valance, no rust, some small dents, $95
68 GTO original upper Ram Air pan $500
68 Firebird original upper Ram Air pan $750
69-71 Deluxe steering wheel, blue $100
66 GTO WS block, 389 tri-power, 4-speed, std bore, magged, $1900
68 Ram Air I heads, 31 casting number, H147 and H167 dates, $3500 very rare heads
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor
68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black
68 Firebird 400 Conv. Auto, Red/Parchment/Parchment
69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor
70 GTO Ram Air III 4spd Conv. burgundy(currently Black)/White/Black
71 GTO 455HO 4spd, Lucerne Blue/Black/Black
71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue
Old 07-29-2022, 01:16 PM
1oldgoat's Avatar
The 70-73 Firebird headlight bezels and the 71-72 GTO fuel sending unit are sold.
Old 08-03-2022, 08:22 AM
1oldgoat's Avatar
I am also bringing an NOS 71 Lemans header panel. 479906 $1200
Old 08-10-2022, 02:51 AM
1oldgoat's Avatar
68 Firebird front air dam is sold.
Old 08-10-2022, 10:40 PM
Ram4king's Avatar
Ram4king Ram4king is offline
Scott I'm bringing a nice 67-68 air dam with me incase anyone else needs one.
Sorry for piggy backing on your ad. Lol
Old 08-10-2022, 10:43 PM
1oldgoat's Avatar
PM sent
Old 08-11-2022, 10:04 PM
vscalera vscalera is offline
I'll be there Saturday, I need the intake block off plates and I'm looking for interior window trim for a 65 A. 330-990-5332. Thanks
Old 08-12-2022, 07:02 AM
1oldgoat's Avatar
Default Block off plates
My spaces have changed to 163 and 164. See you tomorrow.
