Old 07-09-2022, 06:07 PM
tom s tom s is offline
Default First gen alternator move
I have been frustrated over the years with everything stacked up over the fuel pump on the drivers side.I know engineers do thing for a reason but this time I did not agree.I finally moved the alternator to the passenger side and it allowed me to mount a fuel filter where I wanted.IF anyone is interested PM me and will help out.Tom
ID:	593989   Click image for larger version
ID:	593990   Click image for larger version
Old 07-14-2022, 05:23 PM
Took the car for a ride to get gas today,no issues!No belts flipped,all looks good.Tom
Old 07-14-2022, 05:51 PM
ponchonlefty ponchonlefty is offline
what brackets did you use? i may be thinking the same thing.
Old 07-14-2022, 06:11 PM
1963 non AC alt bracket.Did some surgery on the alt PS bracket to remove part above the fuel pump.Tom
Old 07-14-2022, 06:57 PM
cool, thanks for the info. i may have to look into that. i was thinking of using a mini alternator i have no power steering so in case i need to swap sides this looks like a nice option. i can fab brackets if i need to.
Old 07-15-2022, 01:32 AM
dataway's Avatar
dataway dataway is offline
How is that alternator supposed to keep me cool in the summer
Old 07-15-2022, 10:25 AM
Move to a cold state!Tom
Old 07-15-2022, 10:26 AM
There IS a 63 A/C-alt bracket avail!Still keeps the drivers side less busy!Tom
Old 12-19-2023, 10:48 PM
TTT for a FWI.Tom
Old 12-22-2023, 05:04 PM
RocktimusPryme's Avatar
RocktimusPryme RocktimusPryme is online now
I now have CVF brackets, but I would also like to know how you did that exactly.
This would be useful for people who want to run a Type II Power Steering pump as there is very little room for adjustment with a Type II pump on the stock First gen Brackets. I also have long absolutely loathed the factory late 60s double strap alternator setup, so this looks like an improvement all the way around to me as long as you dont plan on AC.
Old 12-22-2023, 05:17 PM
As said there is a alt/AC bracket made for the pass side in 63,some one that needs AC can try that out.Tood Zimmerman might be a source for it.Tom
