Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 06-18-2022, 08:43 AM
GTOFTW GTOFTW is offline
Default 12 bolt posi rear
Fits 68-72. Factory 3.73 rear now has 5.13 gears. Clean inside. Ready to bolt in and do burnouts or
Swap out the gears. 1500 or b/o plus the ride. Located in upstate NY.
Old 06-18-2022, 09:55 AM
https://forums.maxperformanceinc.com...1&d=1655560313
ID:	592958   Click image for larger version
Old 06-27-2022, 01:20 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
So no chance this fits in a 64 a body?
Old 06-27-2022, 01:29 PM
It fits, just an inch wider overall. All 64-72 A-body rears will interchange.
Old 06-27-2022, 01:44 PM
Bman is correct. It will work
Old 06-27-2022, 02:15 PM
thanks guys. so if its an inch wider - in practical terms my back tires would stick out an inch? and if I understand backspacing correctly (which may not be the case) i would need to get new rims with different backspacing to put tires back to original?
Old 06-27-2022, 02:17 PM
One half inch per side - one inch overall width increase of the rear end assembly.
If you have some room on the outside as in more than 1/2” then your current wheels should work.
Old 06-27-2022, 02:23 PM
thanks b-man. so 1/2 inch on one side is not going to be noticeable I would suspect?
The Following User Says Thank You to MidnightAuto For This Useful Post:
Old 06-27-2022, 04:12 PM
AG's Avatar
AG AG is offline
What is the code on the axle and what is the date code?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 06-27-2022, 07:16 PM
NF stamped on tube. Looks like K87 date
Old 06-27-2022, 08:25 PM
AG's Avatar
AG AG is offline
There should be two letters followed by 4 numbers followed by a single letter stamped into the axle tube. I think a 3.73 rear should be a K5 code for posi and K4 for non.
Old 06-27-2022, 10:23 PM
Sorry, CI stamped on axle tube
Old 06-27-2022, 11:40 PM
Gach's Avatar
Gach Gach is offline
It’ll fit in a 64 GTO, took one out of a 70 GTO and put it in my 64 GTO yes about 1” wider. Still was able to get a 11” slick on.
Old 06-29-2022, 10:27 AM
AG's Avatar
AG AG is offline
Can you post a picture of the axle code and casting date?
Old 07-01-2022, 03:21 PM
redhawk44's Avatar
redhawk44 redhawk44 is offline
Definately no expert here, but will rear end that takes a 3.73 take a 5.13 gear as well? I thought that a 3 series took the 308 and 373s and 4 series took 4.11s and such. 5 series for the 5.13 and so on.
Let's make welfare as hard to get as Veterans benefits!
Old 07-01-2022, 03:44 PM
They make 373s that fit on a 4 series carrier
Old 07-01-2022, 04:34 PM
redhawk44's Avatar
Okay, Does a 5.13 fit that series?
Old 07-01-2022, 05:29 PM
They are GM gears so I'm going to say yes. They are thick so it might even have a 3 series. I'm sure the experts will correct me if I'm wrong
Old 07-02-2022, 09:10 AM
The Champ's Avatar
My '64 with a '68 12 bolt.
It's all about the rim backspacing.
I currently run 245/50/17's, but have run 255/60/15's also.
The 15's were on 15x7's with 4.25" BS. The 17's are on 17x7's with 4.625" BS
Name:	GTO DSC_2082.jpg
ID:	593560   Click image for larger version
Name:	GTO DSC_2083.jpg
Old 07-05-2022, 02:02 PM
Still available
