Old 06-15-2022, 01:45 AM
Default 4 speed console measurement needed
I am installing a TKX in my 71 and am thinking of using a repop console. I need to know the distance between the shifter hump and lower edge of the console to see if it will clear.
Thanks.
Old 06-17-2022, 03:40 AM
Hoodshaker's Avatar
Hoodshaker Hoodshaker is offline
Here's some rough measurements. Roughly 2-7/16 on the lowest side. As the pics show I pulled the upper bezel but did not remove the boot or it's retaining plate so you can add the thickness of those to the depth as appropriate.
These aren't exactly precise measurements but if you need something better let me know.
ID:	592907   Click image for larger version
ID:	592908   Click image for larger version
ID:	592909   Click image for larger version
'09 Magnetic Gray Metallic G8 GT
'79 T/A Solar Gold Metallic W72/WS6
'71 GT-37
Old 06-17-2022, 10:08 AM
That is precisely what I needed - thanks for taking the time to get it.
I can run a console with the TKX at the proper angle.
Old 07-03-2022, 08:59 AM
gman005's Avatar
gman005 gman005 is offline
I put a TKX in my 72 and had to modify the shifter porch.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
