69 t/a 3spd manual
Hey all, I've owned several GTO's & am new to Firebirds; found one I had to have & jumped in head first. 69 t/a orig cali car, solid unbelievably preserved body, sitting in dry storage unused approx 30 yrs. Orig RAIII, 3spd dearborn, runs & drives (after dealing with rotten fuel system). Research shows 15 3spds were built, only 1 built in Van Nuys, and this is believed to be the one. (correct me if I have bad info, anyone).
I'm in the process of pulling the motor, as it leaks oil & I'm looking to freshen it up. The first challenge I'm dealing with is the confined space in engine compartment compared to the mid size goats, but I'm learning as I go along. My biggest obstacle right now is removing the tranny. The upper mounting bolts to bellhousing are in extremely tight quarters on the dearborn top loader. Can't even get a crowsfoot in there. This has got to be serviceable without having to pull the motor/tranny out as a whole. Pontiac folks are the best out there. Any helpful tips or advice would be greatly appreciated., and feel free to jump in with any thoughts you have on this car. JAB |
If you're pulling the motor for oil leak, why not pull it with the bellhousing?
I'd take the tranny off then pull engine/bellhousing together. Or even leave tranny on and pull it all. The bellhousing bolts are a pain to get to. Usually taking driveshaft out, pull crossmember and let the tranny hang down gives some room for bolts. (and lots of extensions/u-joints)
You should be able to access them after removing the trans crossmember and allowing the trans to drop down.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
That TA was for sale for a long time on line. Super solid looking car, glad it found a home finally!
Those bellhousing bolts are a bigtime pita. even my six banger was hell to get at. better to remove engine with bellhousing as mentioned above. (no such luck with automatics).
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
Congrats on your find!! I own one of the Norwood 3 speed T/A’s although mine had a non original drive train so not original as yours. As stated, pull the motor with the bell housing on and make life easy on yourself. With the rad and distributor out there will be plenty of room..
We also have one of the 3spd 69 T/As. It is totally original as the day we bought it in 1977 for $3000. Somewhere I have a letter from Pete McCarty that he sent me in the early 90s listing the VIN#s of all the 3spd 69 T/As built. IIRC......the list only had 14 cars on it with only one of them having the tach and guage package. That car is the one we still own. It also came with the formula wheel with the wings down bird horn button.
Thanks to all for your replies and comments. Any info on this car is certainly welcome, as there's not much of a paper trail on it unfortunately. I'm going on hearsay from previous owner.
The story goes: sold new in San Diego, a woman bought it. Wanted the 3spd because insurance was cheaper than a 4spd. She sold it to a neighbor who had it for a few years. Was then purchased by a gentleman who lived in Phoenix. Spent time there till he relocated to Florida, where it was stored in one of those inflatable bubbles for a good part of 25 yrs. He then sold it to a dealer in NC where I found it. He had the car for 7yrs where it mostly sat. I tried to contact the dealership that sold it new. As fate would have it, the dealership was sold about a half year ago. I pulled the rear seats & removed the carpet looking for build sheet, had the tank out also. Nothing. I hear it was sometimes put on top of glovebox. Will be checking there next. With all your helpful advice, I'll be pulling the motor/trans out this coming weekend. Thanks again! |
FYI: That Dearborn trans is heavy!
Nice driveway…
'69 R/A III Firebird Convertible 14.0s @ 100.8mph AMA/OEM/OER |
The Following User Says Thank You to rdl For This Useful Post: | ||
I owned a 69 Van Nuys TA for a while, 4-speed, tach-n-stack and blue Custom trim. When travelling to pick it up in Santa Monica (I lived in Orlando at the time, 1987) I recall meeting a guy and his son in/near Phoenix who owned a couple or three 69 TA's including one that was another Van Nuys car. If not mistaken they were named Linxweiler, maybe Bob and Lou?
May be your car? As an aside, I sold my car in 1996, it went to Michigan. |
That driveway is a rear-wing rich environment.
I had a Dearborn 3 speed in my 66 GTO, and there was one tranny to bell housing bolt that I found impossible to install or remove, I THINK it was the top left one. I went to Harbor freight and bought a cheap set of S shaped wrenches, it did the trick 1/2 turn at a time, but it worked!
Thanks to all for your replies. FYI, I used a swivel socket to get to the hard to reach trans to bellhousing bolts, after removing crossmember & tilting tranny/motor asm downward. There was just enough room to get to it using a long extension. The universal swivel with socket attached to it didn't allow enough room. Tranny's out now, motor is next.
Einstein: the guy from Phoenix was named Steve; he had a brother who also had t/a's & GTO's, & also hung in circles with like-minded folks who I'm told had a t/a &/or GTO or two. The guy you spoke of may have known these guys. JSuchma: would love to see that list if you come across it. That's good stuff! I hope to be chatting with you to compare notes on your car if you don't mind. I'll be looking for someone familiar with Pontiac motors to freshen mine up. I'm in southeast VA, but will travel for someone reputable. If anyone can recommend anybody, I'm all ears. Thanks again to all. |
Man, you're not lying! That S.O.B. had some weight to it.
I'm trying to authenticate my gearbox, and can't find a vin# on it. Only a riveted tag with"RAT E1 054569". I'm curious if yours has a similar tag, or a vin# stamped on the case. Thank you. Appreciate any info you may have. |
Its on the top left..
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express 2024 Cadillac LYRIQ |
Great history on these cars guys, really like hearing about these little niches of different cars . That TA parking garage (driveway shot) is pretty amazing. Very cool !
Thanks for sharing these cool cars and there stories w us.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
I finally found the letter Pete McCarthy sent to me about the 69 TA 3 spds. As you can see, only 14 left the factory this way. Ours has the tach and guages.
The Following 2 Users Say Thank You to JSuchma For This Useful Post: | ||
