Old 04-15-2022, 04:58 PM
ponchorob ponchorob is offline
Default Exessive Crankshaftplay cause for transmission failure
....is it possibble that to much crank play pushes on the torque converter and further on the inputshaft and make damage inside the autonatic trans mission. I only know it the other way or this only direction...when the converter pushes on the crank and causing thrust bearing failure....
Old 04-15-2022, 06:13 PM
ponjohn's Avatar
ponjohn ponjohn is offline
It's the other way around, trans failure or convertor issues cause the thrust to wear.
Old 04-15-2022, 08:45 PM
73 TRANSAM 73 TRANSAM is offline
Normally when the converter ballons up it wil mess up the thrust bearing and will also damaged the internals of the oil pump housing when it doesn't have the .125 required flexplate to converter clearance. But I doubt that it will push the input shaft inward.
Old 04-15-2022, 09:03 PM
Half-Inch Stud's Avatar
For every Thrust Bearing failure, please Check the Front pump gear for galling, to confirm such thoughts.
If so, then converter was balloning beyong the allowed clearance.
