Old 04-11-2022, 10:29 AM
1968junkerjim 1968junkerjim is offline
Default 1977 trans am th350 lines
I’d like to know what the fitting size is on a 1977 TH 350 transmission looks like 76/77 are different from all the other years looks like maybe 5/16 threads? I ask because I’m putting a 77TH 350 in a 68 Firebird and I need to order lines.
Old 04-11-2022, 09:03 PM
I will just orders line for a 68 firebird I guess if fittings are different at Tranny I’ll order new ones. just wanted to order everything at one time
Old 04-13-2022, 10:29 AM
78w72 78w72 is offline
if you know 76/77 are different size threads than other years, then the 68 lines thread size probably wont be the same, but you probably need the 68 lines to fit the car vs 76/77 that will be shaped different or different lengths.
best to confirm what size the lines are for the 68 radiator & 76/77 transmission. they do make adapters/reducer fittings with different threads if needed.
