Old 04-10-2022, 10:50 PM
Poncho60 Poncho60 is offline
Default Plasticote 208 vs Bill Hirsch equivalent
Anyone have an idea how these two engine paints compare colorwise?
Thx in advance for any feedback.
RA
Old 04-10-2022, 11:14 PM
Stuart's Avatar
Stuart Stuart is offline
Unfortunately, Plasti-Kote paint was discontinued a few years ago. https://forums.maxperformanceinc.com...d.php?t=840655
The Following User Says Thank You to Stuart For This Useful Post:
Old 04-11-2022, 10:35 AM
Thx for the reply. Just looking for info on the color match.
Old 04-11-2022, 12:44 PM
higgenslake higgenslake is offline
Try Dupli Color DE-1610 available at Summit
Old 04-11-2022, 01:31 PM
61-63 61-63 is offline
Duplicolor 1610 isn't the correct color. The best thing you can actually do is take a valve cover or other component with some original paint still on it and take it to an ACE hardware store and have them scan it and then mix up some oil based paint for you. Some have the ability to also put it in a spray can I think but most do not so you will need a compressor and gun to shoot it. ALL of the commercial paints, including Hirsch, will burn off of the exhaust bosses on the heads and heat crossover on the intake, no matter what they claim, so the oil based mix from ACE hardware is as good as anything out there.
Old 04-11-2022, 02:01 PM
jhein's Avatar
jhein jhein is offline
Not trying to be contrary here at all but, my current motor was built in 2019. It has the correct appearing metallic blue color for '70. I don't know what brand paint they used but I seriously doubt they did anything special, it was a very basic/economy build. Probably just whatever rattle can they found. I have only a slight discoloration around the center exhaust ports with no hint of peeling. For full disclosure, It has only about 1500 miles since the rebuild. Maybe over time that would change, don't know, but I would think if it was gonna burn off it would have happened by now? I wonder how much prep has to do with it? I'm using the Bill Hirsch paint on the new motor.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 04-11-2022, 02:31 PM
tempest1964's Avatar
I think the Plastikote 208 is for '65 and earlier Pontiac engines. Don't know if this would have a bearing on durability. Definitely not the same as the '70 metallic blue.
Old 04-11-2022, 04:44 PM
The car is a 1960, so I know which color I'm looking for. I have some of the Plasticote 208 on the engine now and I have some left unused, but not sure if I'll have enough for some work I have planned. Not really all that concerned about the paint discoloring on the crossover btw.
Old 04-11-2022, 05:15 PM
rwfisher's Avatar
rwfisher rwfisher is offline
Butler is showing this as their recommended replacement for Plasticote 208. Not sure how your match would be. I would think Hirsch would be the best option though although their usually a little glossier than Plasticote was..
Old 04-11-2022, 06:14 PM
25stevem's Avatar
25stevem 25stevem is offline
If I needed metallic blue I would blow the bucks to get Eastwood’s ciramic Pontiac blue.
It’s 67 bucks a Qt and you have to spray it, but it stands up to 650 F.
If you first spray on a coat of high heat Aluminum header paint it should hold up a dam long time!
I do stuff for reasons.
Old 04-11-2022, 07:21 PM
Torquewar's Avatar
Torquewar Torquewar is offline
Couple guysI know used the Eastwood line, very good results. That will be my go to down the road
