Another 'what will it make' post
Never done this before but with the new engine now in the Trans Am I thought it might be interesting to see what you guys think. Probably won't be able to get the car to the track until this fall because of rear end work that will be needed plus having a roll bar installed but having fun driving the car in the meantime. Anyway the combo is as follows: 400 block with Scat stroker crank, Eagle rods and Icon pistons yielding 10.6 compression, 463 cubes. Cam is a Lunati solid roller with 262/270 on a 110 icl +6. Cam degreed at 105. Top end has KRE d-ports at 325 cfm and a Northwind intake port matched, QF 950 carb. I currently have Hooker 1&3/4 super comps out to full 3" exhaust with the Dr. Gas x-pipe and Dynomax Ultra FLows. I know I will benefit from bigger headers but need to use what I have for now. Forgot to add that the rockers are 1.65 yielding .640 lift.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
575-600hp on a conservation dyno. You'll need the roll bar!
Im gonna say over 600...like 620.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Similar build as mine, but yours has a little more cfm and cam, I am also going with 620 at the crank...
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
I'll say. 590 hp.
Chassis dyno? I’ll say 540hp
585 torque and hp at the crank all day likely
I thought I might add a pic or 2.
So is it a engine dyno or chassis? That will effect peoples guesses lol
A good 600+ at the crank. Nice shop !
470-500 on a chassis dyno
67 Firebird 3440 lbs, Pump gas 537 IA2, tiger heads, 4.86 rear, 32 x 17.5's, full interior, 4 mufflers, street shape 1.36 60', 6.11@113.42 1/8 mi. 5.67@123 on small shot. |
Hey prostreet64, I hope you don’t mind I sent you a PM.
Thanks Murf |
Darby, if and when I can get it to a dyno it will be at the local speed shop which has the chassis dyno only, but I am interested in what #s you guys come up with for either an engine or chassis dyno.
Murf, don't mind at all, I will look for it.
Thought I already posted on this one Chassis dyno: 620 hp times 85% so 527 HP.
Tom V.
Thanks man! I would guess 575 hp. Sounds like a great build. Murf Sent from my iPhone using Tapatalk Pro |
630 @ the crank
Jd tuning up here in Lake City just recently opened and has a Mainline chassie dyno.They allow drivers to make the pull,unlike Rollins.Anyways i made 500 to the wheel with a oldfaithful hybrid roller.I suspect u should make more
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
