Old 04-02-2022, 02:39 AM
Goated66 Goated66 is offline
Default WNTD: 1970 Trans Am parts- need a few minor things!!!
Picked up another Lucy Blue Trans Am today. Looking for a few original parts to make it right:
Ram Air battery cable heat shield tube
Accelerator bracket
Heat riser shield off driver manifold
Long intake branch with heat riser valve
40838 fuel pump
Fuel line pump to carb
Sticker kit or whatever’s available
Here’s a few details on the T/A
Lucy blue/deluxe blue interior
4spd, A/C, power windows
Original engine/trans
Norwood built but looks to have been in CA for most of its life. Paint, interior, drivetrain restored. Few little hokey things to sort out. I know some repops are available but I’d like to find good originals if possible. Pics to follow.
Thanks again!
Old 04-03-2022, 07:09 PM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
Default Fuel line
I have this available, don't know from what it came from, I got it in a parts lot I bought.
Old 04-03-2022, 08:04 PM
Thanks @yahooskidoo, but not quite right. Found the correct 40838 online this morning. Much appreciated though! Still need:
1. Exhaust manifold heat shield (probably going to go with a repop)
2. Accelerator cable bracket (bolts to manifold - repop likely)
3. Air cleaner snorkel for a Trans Am (the one on my car is missing for some strange reason)
4. Original sticker/decal kit for a blue '70
5. Original fan
6. Looking to trade a Rochester 7040570 (Ram Air III Auto, Julian Date 3189) for a 7040573 (Ram Air III Manual)
I appreciate any leads...
Old 05-19-2022, 10:22 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
What's the build date of your car? I have several fans and will see if I have a correctly dated one.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 05-19-2022, 10:36 PM
RAJ7395's Avatar
Checked and I have 3 480033 fans with two dated D70 and one dated F70.
I am in need of one 480033 fan dated in late 70 for my early 71 built TA.
Old 05-30-2022, 08:27 PM
giles's Avatar
giles giles is offline
FYI you don’t need this. Ram air cars did not have a tube for the positive cable. The cable routes underneath the left manifold. Original cables had an insulating wrap (maybe an asbestos based material ? In that era). There should be 2 small brackets to locate the cable and I suspect they are made of unobtanium.
