Oil pan Gasket
Hi: Anyone used or know if these oil pan Gaskets are of the same quality.I've used the BOP pan gasket with great success. Thanks.
https://www.summitracing.com/parts/sce-228090?rrec=true https://butlerperformance.com/i-2445...tegory:1302979
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick. Best so far 9.95@134 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. |
+1 on the BUTLER
The Following User Says Thank You to 67Fbird For This Useful Post: | ||
I've never used any of the one piece formed gaskets. Tried to once but it was broken in shipping. Interesting that if you look at the review on the Summit link one of those folks had theirs arrived in less than desirable condition.
Instead of using "special" gaskets I've been using Felpro stock oil pan gaskets but make my own custom gasket for across the rear main cap. Since I started doing that deal haven't had the first drop of oil leak from one of these engines around the oil pan. I purchase the material in a large sheet and cut the gasket to fit with a razor knife. It's not fussy and I make them wide enough so they can't slip or have any direction to go and "squeeze" out when you tighten the pan down..........
The Following 3 Users Say Thank You to Cliff R For This Useful Post: | ||
Thanks for the write up and pics Cliff. I too have a sheet of cork gasket that I bought and used on other engines. I actually used the BOP gasket on our IA2 and it's been very well sealed. I did make a spacer for the front of the oil pan out of metal which filled the void nicely. So far so good. No oil leaks. I kinda wondering on price difference on what appears to be the same gaskets that I posted. Thanks
All of the one-piece oil pan gaskets listed are the BOP One-Piece Oil Pan Gasket. The ones Summit sells are repackaged and branded by SCE. They shrink wrap to cardboard and have had issues tearing the back of the gasket. We have made them aware of the situation. We also sell direct cheaper than either of these sources. www.bopengineering.com
Wade Congdon BOP Engineering Hi-Performance Specialty Parts for Buick, Olds, and Pontiac www.bopengineering.com |
The Following 2 Users Say Thank You to Wade Congdon For This Useful Post: | ||
Looks like $59.99 through BOP, compared to $135.99 from Summit, more than 50% cheaper from Wade. Butler marks it up $5, to $64.95.
