Old 02-14-2022, 02:22 PM
misterp266's Avatar
Default Unique LSR motor
They hold a record using a flat head Dodge four. Now they are going after a new record using a Pontiac top end on their Dodge motor.
https://www.facebook.com/MontanaDodgeBoys
ID:	584103   Click image for larger version
ID:	584104   Click image for larger version
ID:	584105   Click image for larger version
" Darksiders Rule "
The Following 2 Users Say Thank You to misterp266 For This Useful Post:
Old 02-14-2022, 02:25 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Interesting
Go fast, see Elvis!
Old 02-14-2022, 02:56 PM
25stevem's Avatar
25stevem 25stevem is offline
My guess is that it’s a 71 to 73 Dodge 1.5 L L4.
They start life at ( 3.389” x 2.531” ) ”91.4 CID, so I wonder what it is now and would also love to know how far off the Pontiac head bolt pattern is!
With only a 3.389” bore size in stock form they must have welded up the chambers big time to reduce the valve size!
I do stuff for reasons.
Old 02-14-2022, 03:01 PM
misterp266's Avatar
With only a 3.389” bore they must have welded up the chambers big time to reduce the valve size!
They only made flat head fours up until 1933. Stock was 3.625 bore.
" Darksiders Rule "
Old 02-14-2022, 03:42 PM
25stevem's Avatar
Ah ok, did not know it was a flat head and that old!
Old 02-15-2022, 04:35 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
No other motorsport is as diverse (goofy?) as landspeed.
The Following User Says Thank You to Jack Gifford For This Useful Post:
Old 02-15-2022, 05:46 AM
Tom Vaught's Avatar
Boost Engineer
Ron Main, the last I heard, still holds the record for the Flat Head 4 cylinder engine (believe it is a 1946 engine) that has traveled the salt to over 300 mph in a streamliner. But have not followed that class in the last few years.
http://flatfire.com/
Block: Ford 1946 59a V-8 Bore: 3.307 Stroke 4.375
I WAS PART OF THE TEAM THAT WAS AT BONNEVILLE IN 2001 WHEN THEY SET THAT RECORD, (Over 300 mph),
was cool hanging out with the Landy brothers and Bruce Crower. RIP Gentlemen.
Tom V.
ID:	584136   Click image for larger version
Old 02-15-2022, 07:15 AM
25stevem's Avatar
And how does this info about the Ford relate to this Pontiac headed Dodge other then they both run or ran on the flats?
Old 02-15-2022, 07:32 AM
GTOGEORGE's Avatar
Pretty cool!
GTO George
Old 02-15-2022, 12:31 PM
Tom Vaught's Avatar
Boost Engineer
It relates because both engines would fall into a given class:
"4 cylinder with modified heads".
So then you have the record for that class and say that the Ron Main streamliner held that record from 2001.
So then you have to decide if you are going to build another streamliner
or go into a different class of race chassis that has a different record.
Building a streamliner that works on the salt, means that you have to go thru
being qualified on the 200 mph 3 mile course FIRST.
Then if you have enough runs to show that you can (and the vehicle can) handle 200 mph then you can try to run in the 200 to 300 mph class to set a record. If you are just out there to have fun you still have to prove that you are safe driving in a given class to the Tech people.
Both run on the salt flats means you know nothing about how the racing works. Good beginner question though.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 02-15-2022, 01:32 PM
GTOGEORGE's Avatar
Have FUN with that question! LOL!
GTO George
Old 02-15-2022, 02:53 PM
Tom Vaught's Avatar
Boost Engineer
I answered that question George. Read the previous post.
If you have never done it you are just stirring the chit, as usual.
Tom V.
Old 02-15-2022, 02:56 PM
GTOGEORGE's Avatar
Tom V.
Wasn’t talking to you!! LOL!
GTO George
Old 02-15-2022, 05:20 PM
misterp266's Avatar
Many classes at Bonneville George. That Dodge set the record in VF4/BFMR, which is not a streamliner class.
Vintage Flathead 4 / Blown Fuel Modified Roadster.
By adding the Pontiac OHV head (actually 2 heads) their class would change to V4/BFMR.
Like Jack said, “ no Motorsport is as diverse”!
" Darksiders Rule "
The Following User Says Thank You to misterp266 For This Useful Post:
Old 02-15-2022, 10:19 PM
Tom Vaught's Avatar
Boost Engineer
Obviously misterp266, you actually know something about the Bonneville Salt Flats and the different classes. The first year I was there I was pitted next to Richard Holdener and his girlfriend (at the time, now wife), and Ron Main's streamliner pit crew. I was a member of Ron's team
as were Bruce Crower and the Landy brothers.
Banks and Giesler were a few hundred feet away as was Al Teague who at the time was the fastest guy on the salt if you did not count the jet powered chassis that held a record there.
The Pontiac Trans Am with the BB Chevy engine and twin turbos (driven by Don Stringfellow and owned by Banks) was a bit farther away.
Glad you have knowledge of the classes and the racing at the salt.
Tom V.
Old 02-19-2022, 10:23 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
thats what happens when people with money know mechanics who are bored!
The Following User Says Thank You to 67Fbird For This Useful Post:
Old 02-19-2022, 11:12 AM
694.1 694.1 is offline
67 has the quote of the week!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 02-19-2022, 11:48 AM
misterp266's Avatar
I think it’s more people who like a challenge and have the ability to think outside of the box. They aren’t paying someone else to build them a motor, they are doing it on their own. Similar to Jack deciding to build a DOHC M/T Hemi four cylinder motor for his LSR car.
In a world of full of boring LS motors, it’s good to see what people with vision can produce. True hot rodding.
" Darksiders Rule "
Old 02-19-2022, 04:32 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Thank you guys for doing and sharing all this that keeps our sport alive, inventive and interesting.
Craig
Old 02-20-2022, 02:21 AM
Speaking of money...
In 1985 when I first built the M/T hemi V8 I needed to make my own copper head gaskets. But in recent years I can get them custom-made by SCE. I just bought one gasket and a spare for the hemi-four... $230! It may be time to get that sheet of .022" copper out from the rafters and dust off the old punches.
