Old 02-06-2022, 07:46 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Default Front outer bearing size in '78
So all these years I believed the shop manual that 78 and 77 took a different front outer bearing. Pulled off my 78 original rotor today and measured-same size as earlier 0.750 ID. So maybe '79 is the correct year many other sources have-just not my 78 manual.
Skip Fix
Old 02-07-2022, 08:45 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
79 is when they changed BOMK.
Old 02-07-2022, 10:30 AM
Skip Fix's Avatar
My 78 manual even has a picture of using a 77 rotor on 78 and vice versa saying 78 changed.
Skip Fix
Old 02-08-2022, 03:11 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Changed in 1979. Check your spindle. Part numbers are stamped on the inside of them, and for '79+, the numbers are 14012595 and 14012596 (the service manual will show those numbers for 80-81, but they have been found on '79's as well). If those are the spindles (aka knuckles) you have, then that's how you'll know you need to get 79+ wheel bearings.
For reference, if you end up having to change the spindles, they do reproduce BOTH the 1970-1978 and 1979+ spindles in stock height, you just need to know where to look. CPP sells the new 70-78 ones, even though their listing on their website says they're out of stock as well as the outsourced listing on classic industries, this is inaccurate. Just call CPP themselves, they have a ton of them. Then for '79+, the QA1 repros (#9056-104) match perfectly. Sadly, I didn't find this out until AFTER I searched tirelessly for a NOS passenger side 14012596 unit to replace my original spindle due to a lower ball joint failure attributed to an egged out tapered hole in my original knuckle.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 02-25-2022, 02:10 PM
Skip Fix's Avatar
Here you go from the manual.
Mien was a fairly late build in 78 too.
Thanks for the numbers. I guess I could have looked at my 81 spindles for casting #. Swapped on the 12" rotor new B spindles on it. I think I got the last GM 12" spindles around.
Name:	78 rotor.jpg
Skip Fix
Old 03-02-2022, 02:34 PM
autobahn autobahn is offline
Look at the bearing number, order same
JIM
Old 03-04-2022, 08:06 AM
67Fbird's Avatar
NOPE...you didn't.....lol
I just put a set of 1996 Buick Roadmaster spidles on mine. Only difference with the newer ones is the wheel speed sensor addition.
