Pesky leak at pump to crossover
Iv'e had a lot of pontiacs and never had the leak at the waterpump to crossover seal leak.
now I do. can you get just the rubber seal without having to buy the gasket set? anyone have a better method of sealing this area? |
If you cant find one I will mail you ones.Tom
Is the crossover pulled up and making contact with the timing cover? It might not have been pulled all the way forward before the manifold was torqued down. I also coat each side of the donut with Ultra Grey before assembly and then let things set up for 24 hours before putting coolant back in the system. Some of the newer donuts included in the gasket kits are a little thin and you should have at least the thickness of a nickel sticking out of the cavity when the donut is set in place in the manifold.
The Following 2 Users Say Thank You to lust4speed For This Useful Post: | ||
I always snug up the intake crossover to the timing cover FIRST before I tighten any other intake manifold bolts. If the manifold is matched to the Gaskets and the Heads and the cross-over when pulled tight to the timing cover is shifting the port alignment, I split the manifold behind the water cross-over so that both systems are happy for alignment. Port alignment AND timing. Tom v
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
I weld the holes up completely and drill holes in the thermostat so water can pass thru. I completely delete the crossover. My car takes longer to warm up but it also runs cooler too.
67 Firebird 3440 lbs, Pump gas 537 IA2, tiger heads, 4.86 rear, 32 x 17.5's, full interior, 4 mufflers, street shape 1.36 60', 6.11@113.42 1/8 mi. 5.67@123 on small shot. |
Thanks.
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
You dont have to weld them up,you can drill and tap for pipe plugs incase you want to go back to a thermo.Tom
Ames sells a better seal. It 's a little thicker. Part #N539AL
Never heard of the weld up mod. pics?
thanks, i'll check ames, and thanks for the mail me one offer, very kind. I always separate the water crossover. I think I had a thinner seal and also I put gasket sealer in there but did not let it dry. |
So that hole really isn't necessary for cooling?
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
As the name implies, it's a bypass. The water that goes through there doesn't go to the radiator. So no, it's not for cooling.
'65 Tempest 467 3650# 11.30@120.31 |
The 'bypass' is to bleed air out of the system was what I always thought/was told.
If you're running an aftermarket intake, you can file the raised area around the seal some so the rubber gasket gets 'squeezed' more, which helps prevent leaks. You might have to enlarge the bolt hole in the intake that go to the heads, sometimes they are off slightly and don't allow the intake to be pulled forward enough for a good seal. .
Found this online, and it makes sense.
The bypass feature allows water to flow around the engine, without passing through the radiator, while the thermostat is shut. Without it, the water will not circulate correctly creating hot spots around the engine which could lead to damage. I think some holes in the T-stat would be better, then block the bypass. Everything works as intended, but one potential problem eliminated. I guess I learned something new today!
Is there a downside to this approach? Thanks, James Q
James Quayhagen 1963 Bonneville Safari - Nocturne Blue, 4-speed |
Sealing is accomplished by the donut conforming to and making a seal against the intake, and a loose washer in the recess would allow coolant to flow between intake and washer. A spacer could be set in the recess with plenty of Ultra Grey and it would work okay.
Tom mentioned using a washer as a spacer to obtain proper port alignment, but in this case the spacer is epoxied to the timing cover and effectively becomes part of the cover and the epoxy creates the proper (and permanent) seal between spacer and timing cover. I currently am finishing up an engine where the Tri-Power manifold was about .100" forward and needed to be spaced rearward for proper port alignment. Found a suitable washer and epoxied it in place and ports now align. Could have been the old timing cover or the new intake manifold or a combination of both that created the problem. Usually I do the port check and things are so close no adjustment is needed.
A little bit of that right stuff on both sides of rubber o-ring and it will never leak..
