Looks like the Stroker is a go
OK, so I found a local engine builder, Archie Somers as recommended by VCho455. It's gonna be a 467 stroker. Eagle cast crank and H beam forged rods. Edelbrock 87 cc D port heads. Comp Cams XR 288HR hyd roller cam (520/540 236/242 @ .050). 1.5 rockers. Stock intake, Q-jet and RA manifolds.
Heads ordered today from Butler with the stealth option. Somers is sourcing the rotating assembly and says everything is in stick and will be ordered in the next day or so. :Now the waiting. Project should start in approximately 3 months.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
Sweet!!! Are we guessing HP #'s yet? I say 518 with 560 tq.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
The Following User Says Thank You to 4dblnkldude For This Useful Post: | ||
Sounds like a nice combination
Adding some mild port work definitely wouldn’t hurt. If you have a little extra money to spend the Simms roller bearing cam plate and timing sets are a pretty nice piece. He posts in the performance for sale section.
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
The Following User Says Thank You to R 70 Judge For This Useful Post: | ||
Concur, put it in my last 455 in my 69 bird.
Is this for the 70 or another project?
The Following User Says Thank You to Aus78Formula For This Useful Post: | ||
I was thinking around 500 hp 550 tq. I'd be more than happy with that. We'll know for sure once it's been dyno'd.
Happy days for sure!.
I'll check out the Simms stuff.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share Last edited by jhein; 12-09-2021 at 12:50 AM. |
I would step up to the forged crank if I was you. Then if you plan to step it up in the future, your bottom end is already capable of handling more power.
The Following User Says Thank You to ID67goat For This Useful Post: | ||
x2 on the forged crank. & is there a reason you didnt get the stroker kit from butler too? they pre balance them that will save some labor from the builder. or is somers getting a different kit for less money?
i have the butler eagle/ross kit in my 467 with the forged crank, when i bought it about 5 years ago they had the best price for the quality of parts & was inspected & balanced that nobody else did at the time. |
The Following User Says Thank You to 78w72 For This Useful Post: | ||
As for not getting a kit from Butler, he wants to get all the parts ASAP because he is worried about availability. The kit includes the pistons but I am going to need custom pistons and he won't know the exact specs until he gets all his measurements. It's still the same eagle crank and rods and he is matching the Butler prices.
does butler have an availability issue that would cause a problem? they have the ross pistons custom made so might be able to have them reserve you the rest of the kit after payment & just wait for measurements for the pistons? is the builder matching butlers price including the balancing he will have to do? just an idea to consider for some savings & the forged upgrade for reliability. |
I talked to Somers and the only arguments against the forged crank were money and availability. His supplier was saying late January or February. Butler had it in stock so I just ordered it. Somers has everything else ordered and he wants to do the balancing so that's fine with me. If you price out all the components in the Butler kit, it looks like they are charging round $200 for the balancing. I don't know if it'll be more for Somers to do it but that's how it's going down.
Yep, the whole enchilada. Broken in and full dyno test and tune.
The Following User Says Thank You to jhein For This Useful Post: | ||
Are you going to use the original WS block for this new build ?
Yes, with the stock intake, Q-jet and RA exhaust manifolds. Stock valve covers too (thicker or double gasket). The only giveaway will be the heads.
I'm real interested in your results! I vote for spending your money on a forged crank, ported heads, and 1.65 rockers.
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
I don't know about 1.65 rockers. That's already a fairly aggressive cam don't you think?
I'm no authority but good aluminum heads are still flowing past that .520/.540 lift. Somebody just posted here recently about using that cam w 1.65s/ported heads with great results but I think they had an aftermarket intake. I ran that cam in a 400/iron head combo w 1.50s, it was great. I hear ya on the forged crank availability but think it's money well spent for peace of mind, personally. Your performance goals and budget will decide.
