has anyone installed a ram air iv cam with 1.65 rockers?
With valve springs and valve lengths that will handle the added lift of course.
Of course. I had one with Crower SS roller rockers. Loved it. What are you wanting to know exactly?
I'm building an engine and had a lunati cam for it but the heads I had made up ended up having springs/valves installed that are a tad too short for the cam so I need another cam, so I'm thinking I may get Butler's hydraulic roller ram air iv but with a 110 lobe separation. My heads have 1.65 rockers roller rockers in them. Tom S. suggested I get the old faithful cam and I would like that option but it turns out it too would give me just a tad more lift than I would be comfortable with, so I am looking at the ra iv. What cubic inches, compression ration ratio, and rear end did you have and how did you like it? I will have a 421 with 9.5cr and a 3.42 rear end. Not a race car a '63 Cat sd tribute car.
I am really satisfied with the cam and 1.65 rockers, but I also have Rhodes lifters and a .030 455. I think your combination would benefit from the Rhodes lifters.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
I had a flat tappet Melling RAIV grind. It was 455, 9.25cr, very lightly ported D-port, 3.23 cogs, 64 GTO, 400 turbo with 13" Continental, etc. Ran low 12's on 9" slicks at close to 3800# with driver.
I run a TC02 hydraulic flat tappet cam made by Isky (236/244@.050) with stock ram air iv length valves and stock ram air iv 1.65 rockers in my 428. I believe the lift is about .561/.567 with the 1.65 rockers. My compression is 10:1 and I run a 4 speed and currently have 3:23 gears. I think it would like 3:55-3:90 gears better but does fine with the 3:23's. I like this particular setup. It idles with a loap and pulls to 5,500 very nicely. It has plenty of low end torque and is a handful when you put your foot in it. I've never measured my vacuum at idle but it has plenty to run the power brakes. I would imagine that the ram air iv cam would run very similar to this one.
The RAIV cam combo has been documented to death. Do a search. You can read until you're sick. lol
Here’s the Butler “041” roller cam. Different specs than the factory 041 RA4.
It’s just a marketing name.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
How about someone answer the guys question before giving him different Cam recommendations!
To run over .500” lift safely without cutting the spring seats on what I am assuming are iron D port heads you will need valves in the 5.210” lenght range. You will now of course need longer push rods. You will also then need springs with a installed height in the 1.800” range.
I posted the specs of the roller cam that the OP is wanting to use, so that people aren't confusing it with the flat tappet 041 that we all know. notice that the butler cam has .507/.541 lift with 1.5 rockers. That would be .557/.595 with 1.65's
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg Last edited by Singleton; 11-29-2021 at 01:07 PM. |
The Following User Says Thank You to Singleton For This Useful Post: | ||
Fellas the valves and springs are already in the heads and the heads are done. Jim Robertson did the 127 heads a couple of years ago and put 914 springs in them and valves that will accommodate that Butler roller ra iv cam with 1.65 rockers on top of it, but not the lunati roller cam I already had. I've been fiddling with this car since '07 and have all the stuff to make it look like a real '63 Catalina 421 Super Duty. The block is at the machine shop and I'm about to take the rotating stuff there to be balanced and need to decide on the new cam and am thinking I want to use the Butler roller ra iv with a 110 lobe separation to get a little more rumble, hence my question.
I installed two RA-IV cams in the two RA-IV engines I repaired and posted about in a different thread.
Both were 1969 engines with the 1.65 rockers stock and the 1.8?? tall "Factory Springs" for the application. Tom V.
I failed to thank everyone for the responses so thanks, very much appreciated.
Also NOTE: if you are running iron heads you MAY need ot clearance the push rod holes depending on WHICH 1.65 rockers, WHICH lifters you are running. |
Guys,the heads were designed for 1.65 rockers and were never avil with 1.50s.Not sure if 65-66 1.50 rockers will even work properly on the heads.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
No I just wanted to know if people had used the original ra iv cam with 1.65 rockers. I should have clicked around instead of asking probably and have probably read about it on here twenty times having been on here twenty years now. I'm glad I asked though there are some good answers above. I think I'm going to get Butler's roller version and will come back when I get this engine together later next year and say what I think about it and post some pictures too.
I made that mistake ONCE in 1971. Tom V.
TOM!Its a 62 421 SD 127 head!Tom
The Following 2 Users Say Thank You to tom s For This Useful Post: | ||
Thread Tools | |
Display Modes | |
