Old 11-21-2021, 02:20 PM
BertMac's Avatar
BertMac BertMac is offline
Default 1967 doors vs 1968 doors
I'm thinking about doing away with the wing vents on my 67.
Is there a difference in the 67 doors and the 68 doors?
I'm guessing that I would have to use the 68 window tracks but why wouldn't I be able to do this?
65 Mutant
1967 Firebird Fatass
70 Mutant II
I want my driveway to look like I'm stuck in the 70's!!!!
Old 11-21-2021, 02:52 PM
einstein's Avatar
einstein einstein is offline
Hinges are 3 bolts on 67, 4 bolts on 68.
The Following User Says Thank You to einstein For This Useful Post:
Old 11-21-2021, 10:44 PM
frankyboy455 frankyboy455 is offline
upper part of the door (inside) will make it impossible to fit a 67 door trim on a 68 door frame.
Old 11-22-2021, 07:45 PM
694.1 694.1 is offline
Betcha it's been done... Might be easiest to grab the roof too?
If you can put a bubble top on a '61...
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 11-25-2021, 02:29 PM
BertMac's Avatar
so, to clarify a little.. I have a 67, with 67 doors.
Does anyone know if I can just delete the wings windows and use 68 glass and window tracks?
65 Mutant
70 Mutant II
Old 11-25-2021, 05:05 PM
Doesn't look promising to say the least, first is a 67 door, second is a 68 door.
Name:	67 door frame.jpg
ID:	578542   Click image for larger version
Name:	68 door frame.jpg
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 12-18-2021, 08:20 AM
gtobird's Avatar
gtobird gtobird is offline
If you are a skilled metal grafter, I see two options (in theory):
1.) Get a pair of 68 doors, cut the front jam area out of them (where the hinges mount) and weld in the same metal from your 67 doors. You would have to be really good to do this trick and would have to find good 68 doors to do it.
2.) Take your 67 doors and cut out the entire inside metal piece that the window tracks mount to. Weld that part in from 68 doors and use the 68 door guts. To me, this seems easier and this sheet metal is usually good even on doors with badly rotted door corners. You probably wouldn't even need to dress the welds if neatly done as your interior door panels would cover the welds.. I have a pair of 68 doors with window tracks I would sell if you want to do this, but I'm in Wisconsin and don't want to ship entire doors as the cost and packaging would be prohibitive. My doors are pretty rotted, but good in that area. Certainly you could find these locally at a reasonable price.
OJ
Old 12-18-2021, 10:53 AM
amcmike's Avatar
amcmike amcmike is offline
I have a '68, and after riding in one with vents that's one thing I wish it had. Really cuts down the wind buffeting inside when the main window is rolled down. Might look a little cleaner visually, but you may miss their functionality.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
