Old 10-23-2021, 12:04 PM
vertigto's Avatar
vertigto vertigto is offline
Default Reproduction T3 Headlights by Lectric Limited
Just read an older thread about the new reproduction T3 replacements by Lectric Limited with updated bulbs that meet current federal lighting standards. They look good for my mostly original car and are not expensive for the set of 4 ($149). Anyone have these and can comment on exactly how bright they are compared to OEM/halogen/LED?
https://www.lectriclimited.com/sealed-beam-set-89689
Old 10-23-2021, 12:07 PM
Vckline313 Vckline313 is offline
These are new original looking housings with led lights. Love the look, not ricer at all
Sent from my SM-G996U using Tapatalk
Old 10-23-2021, 12:09 PM
179$ for all 4 housings, bulbs, adapters for hi beams
Old 10-23-2021, 01:12 PM
vertigto's Avatar
Manufacturer / link(s)??
Old 10-23-2021, 01:21 PM
Rms lighting... Hector Vega on Facebook.
The Following User Says Thank You to Vckline313 For This Useful Post:
Old 10-23-2021, 05:41 PM
Cardo's Avatar
Cardo Cardo is offline
I have a set of the Lectric Limiteds - they look like OEM T-3 but are Halogen bulbs. I believe if i'm not mistaken that Wagner actually is the manufacturer. I'm happy with them, but they're definitely not as bright as a LED, but definitely brighter than OEM.
"I know just enough to keep me here, but not enough to get me out"
The Following 2 Users Say Thank You to Cardo For This Useful Post:
Old 10-25-2021, 11:21 AM
vertigto's Avatar
Sine they are halogen bulbs, are you using a relay or fine as is (i.e. plug and play)?
The Following 2 Users Say Thank You to vertigto For This Useful Post:
Old 10-25-2021, 11:49 AM
Cardo's Avatar
No need for a relay, just replace.
Old 10-25-2021, 12:36 PM
RocktimusPryme's Avatar
RocktimusPryme RocktimusPryme is online now
Would they not be brighter with the relays?
I was reading an article recently about just adding a relay with direct battery power to the standard sealed beam lights. When you apply direct battery instead of the power flowing to the switch and coming back that can increase luminescence. I would think the same would apply to halogens.
Oddly that Lectric Limited set linked says it doesnt fit my 67? Which I think is a typo. I dont see why it would fit a 4 headlight 68-72 but not a 67.
I had been looking at Hella housings off of Summit and then some generic halogen bulbs. Im afraid to drive my car at night with the terrible OEM lights here in deer country.
Old 10-25-2021, 01:14 PM
OG68 OG68 is offline
The design of the T3 triangle is different. Otherwise they are the same.
2007 Cadillac SRX
Old 10-25-2021, 01:16 PM
Oh okay so its not that the housings wont fit its just some show quality detail that I dont care about.
Old 10-25-2021, 01:22 PM
242177P's Avatar
242177P 242177P is offline
They'll fit. It's mostly the T-3 logo. 60-67 if you want 100% correct, 68-72 have ribs inside triangle.
The Following User Says Thank You to 242177P For This Useful Post:
Old 10-25-2021, 01:33 PM
vertigto's Avatar
FWIW...Lectric Limited said the sealed beams are not halogen bulbs (no relays required - their words), but could not comment on brightness compared to OEM/halogen/LED or provide a lumen/candela value.
Old 10-25-2021, 03:00 PM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
Vckline313 , did you have to modify your original headlight buckets for the leds ?
When I wore a younger man's clothes
Old 10-25-2021, 03:03 PM
Cardo's Avatar
I'll have to do some digging. I'll pull one back out... I seem to recollect the back of mine was stamped as a Wagner Halogen.
Old 10-25-2021, 03:20 PM
bob d bob d is offline
Thumbs up t-3 bulbs
I Have the box that my bulbs came in. It says Improved Brightness to meet current Federal Highway Safety Standards- without compromising originality.
Old 10-25-2021, 03:25 PM
Lightbulb T-3 bulbs
My bulbs do seem brighter compared to the ones I took out which I think were the oem bulbs. Thanks Bob.
Old 10-25-2021, 05:07 PM
i82much's Avatar
i82much i82much is offline
you guys drive me nuts with your fancy-schmancy fuel injection, overdrives, and now freaking headlights that work. whaddya want, a freaking car that’s safe and comfortable to drive? FOR CRYING OUT LOUD! THESE ARE FREAKING HOT RODS! YOU’RE SUPPOSED TO OPEN THE DOOR, BURN YOUR *SS ON THE HOT VINYL SEAT, CRANK THE CAR OVER REAL SLOWLY, BREATH A SIGH OF RELIEF WHEN IT FINALLY FIRES UP, CRUISE AT 3000 RPM AT 50 MPH ON THE HIGHWAY, PULL OVER TO COOL DOWN EVERY 30 MINUTES, AND NOT BE ABLE TO SEE A GODDAMNED THING MUCH LESS ACTUALLY STOP IN TIME TO AVOID HITTING IT WHEN YOU DRIVE A FREAKING OLD HOT ROD!!!!
sheesh. some people. THE NERVE!
The Following 3 Users Say Thank You to i82much For This Useful Post:
Old 10-25-2021, 05:16 PM
My dad was aghast that I had the nerve to go out of my way to install a normal retractable three point harness seat belt in my 67. Because he doesn’t like to wear his seat belt. I was like, you can die in a deer strike if you want to. I’ll pass.
The Following User Says Thank You to RocktimusPryme For This Useful Post:
Old 10-25-2021, 05:25 PM
No that was the best benefit vs most led housings
