Old 10-14-2021, 09:45 AM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
Default Throw Out Bearing Install
I'm installing a new throw out bearing in my car.
The bearing has a point on the surface that fits to the throw out fork. Does this point face into the fork or face out of the fork for proper install?
Or does it matter?
Thank you in advance,
Bob
Name:	bearing point.jpg
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph
Old 10-14-2021, 11:07 AM
Tom Vaught's Avatar
Boost Engineer
I would point it towards the open end of the clutch fork if I were installing it.
Tom V.
Old 10-14-2021, 01:15 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
The large flat surface goes towards the pressure plate. Sorry, miss understood. I think it fits in the middle of the fork so it doesn't rotate.
Old 10-15-2021, 08:07 AM
chrisp chrisp is offline
Does not matter.
Old 10-15-2021, 02:40 PM
Thanks for the input people.
I did receive direction back for Tech Support at a very well known clutch manufacturer.
"That throw out bearing is designed with an anti-rotation cam, you should put the point to the inside of the ‘C’ on the fork."
Bob
Old 10-15-2021, 03:39 PM
Tom Vaught's Avatar
Boost Engineer
Bob
Been there, done that, posted that at 11:07 am (post #2)
People put things on parts for a reason.
Tom V.
