Old 09-22-2021, 08:48 AM
scott70's Avatar
scott70 scott70 is offline
Default Modified stock intake
So I took a shot of modifying my stock iron intake. Tried to copy Cliffs intake pics. Traced out what I wanted and the took a Sawzall to the big pieces. Then took a electric die grinder and blended in the rest. Right side was easy but the left was much thicker and took some time. Using the same 1/2" spacer which has a notch already so I didn't remove any metal from the center divider. Just opened it from a 4 hole spacer to matching the intake.If it doesn't gain any HP at least its lighter now. Lol
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 09-22-2021, 09:16 AM
Half-Inch Stud's Avatar
Half-Inch Stud Half-Inch Stud is online now
Looks real good. Hmmm, i could use that Spacer.
Old 09-22-2021, 12:03 PM
Formulajones's Avatar
Looks good. That's pretty much how I've done them with the notch in a short spacer etc...
With one small exception. I kept the front bores a little smaller to closely match the throttle bores of the Q-jet as per how Jim Hand did it. I think the theory was a little more velocity and better throttle response, but I haven't noticed much difference either way.
https://youtu.be/XqEydRRRwqE
Old 09-22-2021, 02:40 PM
scott70's Avatar
Smaller on the spacer?? The bores on the intake primaries are pretty much stock from about 12 to 3 oclock on the right and 12 to 9 on the left. And the secondary holes are stock in the back part. Pretty just went from the factory holes and blended the sides. If you look at the left primary you can tell the grinder never even touched that at all around 12 oclock position. Hopefully didnt lose much on the throttle response.
Old 09-22-2021, 02:49 PM
On the primaries I leave the thickness in the center divider with blending, pretty much like Jim Hand did it, and taper it in larger as it enters the plenum. The divider quickly tapers in to a skinny center divider between the secondaries. I do the same with a spacer. Shoot me an email and I'll send some pictures if you want to see it.
Not that it's a big deal. I've done them the way you have it too and don't notice any difference, it'll run perfectly fine like that.
Old 09-22-2021, 06:40 PM
cnc's Avatar
cnc cnc is offline
What gasket are u using between this spacer and the carb
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 09-22-2021, 07:53 PM
scott70's Avatar
I use a thicker one between carb and spacer...like a 1/8th" or so. Then a thinner one between spacer and intake. I cut both of those to the shape of the spacer.
Old 09-22-2021, 09:49 PM
cnc's Avatar
cnc cnc is offline
I need to go look and see what I have
Old 09-23-2021, 06:48 AM
scott70's Avatar
Both gaskets started life as 4 holers, Used scissors and utility knife to make them look like thee intake opening.
Old 09-23-2021, 01:02 PM
Got your email Scott, I'll send you some pics tonight as soon as I figure out this computer.
Old 09-23-2021, 04:00 PM
Slick's Avatar
Slick Slick is offline
Here's how I did mine. Looks like I should have spent more time in the plenum radiusing the corners.
The outside of it resembles a RA/HO at first glance. Sure is a lot lighter and runs cooler.
The Following 2 Users Say Thank You to Slick For This Useful Post:
Old 09-23-2021, 04:08 PM
Dang, i have pent-up Cast Iron Intake performance anxieties. My 4234 which matches my R 96 A heads is Stock, and needs the Mahoney treatment. I am willing to settle for the above.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 09-23-2021, 08:00 PM
77 TRASHCAN's Avatar
Looking at post 11. I wonder about leaving the top of the secondary, front to rear divider intact, and grinding a opening below it to connect the sides. Wondering if leaving some of that top F-R divider in place and contouring it for port velocity............have not seen one like that.....I have seen all of Jim Hands doings, for intake plenum mods...
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 09-23-2021, 09:52 PM
That's what Jim Hand was doing on the front portion which I've done on a few as well.. I'm trying to get pics to Scott. Basically the width of that center divider in the front is left in place basically matching the throttle bores of the Q-jet, and then contoured into the plenum. One side needs a lot of grinding to contour it properly, the other side not so much. The idea was to keep port velocity up on the small primaries. I do the same thing with the spacers.
Old 09-24-2021, 07:19 AM
mchell's Avatar
mchell mchell is offline
Mine ended up like this when I was putzing around with intakes…..note the 1” spacer
It couldn’t match the RPM on my combos…..had fun carving it up though!
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 09-24-2021, 07:38 AM
SD455DJ SD455DJ is offline
Here's an SD Perf CNC modified intake to compare to.
Dennis
ID:	573737   Click image for larger version
Old 09-24-2021, 08:02 AM
scott70's Avatar
Dennis
That's the one I was trying to copy. I did find online a pic of the jim hand modification that formula Jones was talking about. Only way to get that shape now would be to get another spacer and shape it to that which now would only be making a 1/2 " ledge.
Old 09-24-2021, 11:30 AM
The SD intake is a copy of Cliff's iron intake. Cliff had posted several times, pictures of his original modified intake.
Shut it off
Shut it off
Old 09-24-2021, 12:05 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
So I'll throw this out -the factory must have had a reason for 4 holes especially going all the way down the deep plenum-and Chevy had several 3 hole factory intakes. Why?
Skip Fix
Old 09-24-2021, 01:15 PM
I sent pictures to Scott how I've done a few of them, which is the old Jim Hand way. I've also done them like the Cliff Ruggle way which Dave as SD has copied for Cliff.
I think what has happened over the years is the Jim Hand way morphed into the Cliff Ruggle way and now the Cliff version is the widely accepted (more recent) way of doing it.
Either one works about identical from what I've been able to tell from my own personal use.
