Old 09-10-2021, 02:21 AM
98 SNAKE EATER 98 SNAKE EATER is offline
Question Removing Reverse Shift Lock on 70 T/A?
Not a fan of the Reverse shift lock and would like to disable it
Is it as simple as removing the rod or is there more to it?
My other 70 T/A never had it and I prefer it to work that way, but I'm guessing sumthin needs to be done about the reverse light circuit?
Old 09-10-2021, 07:43 AM
That’s a different perspective ,just take it off , Rods and bracket
Old 09-10-2021, 07:47 AM
77 Canamman's Avatar
What I did with my '77 TA with the BW ST-10 is I used a reverse switch setup from a 1963 Corvette with the T-10. The switch setup is mounted to the trans. I made a harness that plugs into the original one at the base of the steering column to the new switch. That way if I were to put the reverse lockout back on there would not be a hacked dash harness to deal with. I'm sure there were a few vehicles from the mid-late 60's that utilized transmission mounted reverse switches.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 09-10-2021, 07:57 AM
https://www.heartbeatcitycamaro.com/...-Line-Correct/
Old 09-10-2021, 09:41 AM
padgett's Avatar
padgett padgett is offline
Back in the day you could always tell if a car had the lever removed so did not have to put in reverse to remove the key, the backup lights were always on.
Web Site
Old 09-10-2021, 03:02 PM
Formulabruce's Avatar
I failed firebirds at inspection for this. They would wire up the column so they could get key out, then remove the back up light bulbs . One guy was Irate about it. He left the dealership with brand new back up bulbs, that were ON.
All due to headers that never lasted.
Old 09-11-2021, 03:11 AM
Thanks for all the info
I was hoping it wouldn't be so involved
I only get to drive her a few weeks out of the year, so I'll probably just live with it as is
Now that I think about it, I can't remember if the reverse lights in my other 70 ever worked (been over 20 years since I last drove her lol)
Old 09-11-2021, 06:00 AM
Aus78Formula Aus78Formula is offline
Sounds easier and better to just leave as designed.
