Wenzler Series II shaft rocker question
I purchased a used set of Wenzler heads with the shaft rockers awhile back. I believe the guy I got them from got them from KGTO at one point. I lost the bearings in an exhaust rocker and cant seem to figure out who built the system. Called Jesel and T&D and no luck. No numbers or markings on the rockers. They do have a set screw in the middle that goes thru and spaces the bearings apart. Can anyone shed some light on this setup? Thx!
Sounds like the shafts KRE was selling for a while.
The Following User Says Thank You to PAUL K For This Useful Post: | ||
" Darksiders Rule "
Thx guys. I have a call in to Larry. I will try to get ahold of KRE and see what they say.
Larry said he only used T&D so that's no luck. Maybe KRE will shed some light on it.
Is there a number on any of the others? I think on my stud mount rockers you can read a bearing number in them.
If you can post some pictures I have a box full of miscellaneous parts from those KRE shaft system. I'd be happy to see if I have what you need.
If it is just the roller bearing you need they should be availbe from Berry Bearing they can look them up from the dimensions. If the bearings slip out of the rocker body with little or no effort the rocker body needs work or replacement. (I'm guessing that's to only way you could loose the bearing).
GTO George |
Please tell me that’s not his real last name……? If it is someone must not have liked him or had a hell of a sense of humor!!!
G Geo |
Thats the company name
Yes I know……it was just funny!
GTO George |
Then you'll like this, I believe their parent company is called Boca Bearings
Berry Bearing
Got lots of hard to find bearings not serviced from manufactures. For instance Mandrel bearings for Lawn Mower decks. Last time bout a pair for bout $5 bucks each vs $40-$50 each for Mandrels.
The company started out down here in Boca Raton, hence the name.
Dave Polichena |
The Following User Says Thank You to Dave Polichena For This Useful Post: | ||
PM sent
Thread Tools | |
Display Modes | |
