Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 07-12-2021, 07:14 AM
mysticmissle's Avatar
Default edelbrock wide port set up
can deliver to norwalk. these are originally done by knowlton thunder heads. recently flowed by dave wilcox, and found to be in the mid-low 380s. titaninium valves, pac springs good for 730 lift, pac hardware, edelbrock SD/butler victor, sheet metal valve covers, push rods and lash caps, t & d 1.75 shaft rocker set up
one cylinder, (the only one with epoxy) needs to be resealed, as it developed pin hole, in an effort to make a race this season i swapped to another set of heads i already had. dont want to see these sit, also wont give them away. prefer to seal complete but will keep rocker shaft set up and sell heads and intake, pushrods etc. PM preferred, delivery to norwalk available.
Have gotten a couple estimates in the 4-600 range to fix the port and re do the valve job. $4300 shipped to you for everything i have listed, or 4k delivered to norwalk, with deposit. also will include partial set of head studs, but i robbed a few to use on other set up. i may have enough to make complete, but cant guarantee at this point.
i can send pics, haven't taken any yet. pm phone number,
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 07-15-2021, 09:02 PM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Would you take a Procharger F-2 on partial trade?
Steve 703-615-5027
67 Firebird 3440 lbs, Pump gas 537 IA2, tiger heads, 4.86 rear, 32 x 17.5's, full interior, 4 mufflers, street shape 1.36 60', 6.11@113.42 1/8 mi. 5.67@123 on small shot.
Old 07-17-2021, 08:41 AM
these would be fixed easily enough by removing one intake valve and replacing the epoxy in that port. The 4-600 repair is either welding them up or stripping the head and pouring some ''seal lock"' or equivalent into the water passages and baking the head, light coat of epoxy and touching up valve job if required from heat.
price lowered to 3800 delivered to norwalk or plus actual shipping. will consider trades but not much i can think of needing unless you have an exceptional aftermarket cased powerglide and electric shifter
pm number ill send all the pics you want
1964 540 gto
Old 07-19-2021, 05:03 PM
sale pending thank you
1964 540 gto
Old 08-15-2021, 07:25 AM
sold
1964 540 gto
