Old 06-26-2021, 08:41 PM
rohrt rohrt is offline
Default pushrod checker
Do I need to swap out to a light spring to use a pushrod checker?
What length would I want for testing a Roller lifter setup 7.800 to 8.800?
https://www.amazon.com/Competition-C...73&sr=8-1&th=1
Old 06-26-2021, 09:07 PM
grandam1979 grandam1979 is offline
I just did one last week it ended up at 9.5”
pastry_chef's Avatar
Depends on the method you intend to use to verify pushrod length.
Some mark the valve tip with marker and rotate the engine, an adjustable pushrod checker will likely damage from regular spring pressure.
Using the Straub method you would be fine, there is no strain on the checker.
Get Jesel.
https://www.summitracing.com/search/...checking-tools
Old 06-26-2021, 11:30 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
That’ll work but I like the hi-tech version. Each turn is .050” so no need to measure and strong enough to turn the engine over with springs installed to check pattern.
I checked the one I have with a Starrett OD mic and it’s dead nuts.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 06-27-2021, 11:13 PM
Get Jesel.
"Mark the valve tip" was the way I was going to do it.
I'm not familiar with the Staub method.
https://www.youtube.com/watch?v=o5is9BsH5OU
I assume your referring to this? That is pretty cool.
