Curious, was there ever an 800 vacuum secondary version? I guess it would be a 4175 series?
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
Yes, 4175 all of the 4175 carbs are 650 cfm size. (According to Mike Urich books)
Tom V.
My original Quadrajet died an early death in late 1974 and the local speed shop had the 800 CFM Holley spreadbore on sale for $74 plus tax. Came with a 30cc front shot and 50cc rear. Got a little more serious in the mid 80's and had the choke tower milled off. Didn't pick up even one horsepower on the dyno with back to back testing. Later on tried a heavily modified Quadrajet and then a little larger squarebore and both were basically a push with the spreadbore. Somewhere I have the jets plotted out for changes in air density at the track, but off-hand do remember that the secondary's needed some good sized jets to maintain a proper AF ratio.
2" throttle blades, If I remember correctly. Tom V
Triple Black 1971 GTO |
Summit Racing has a square bore version (M2008 Series) of that carburetor made exclusively for them by Holley as a lower cost alternative to the Holley carburetors. https://www.summitracing.com/search/...20%28Search%29
The OEM spec for this carb was an 8.5 Primary power valve instead of the typical 6.5 used in most Holley performance applications. Do the small primaries used on these carbs creates a stronger vacuum signal? The Secondaries use a typical 6.5.
Use of the 8.5" Power Valve vs the typical 6.5" Power Valves means that Holley Engineers wanted to add more fuel to the engine EARLIER in the acceleration. HIGHER NUMBER MEANS THE EXTRA FUEL COMES SOONER.
Tom V.
There is also a list 6213 800 cfm mech sec. Spreadbore as in my personal example
Mine is list #9023
That is a nice Marine 800 cfm Holley Spreadbore carb built with the "Johnson Linkage" like most all of them were.
"Johnson" was a VP in Holley Engineering. Tom V.
Can you enlighten us as to what the "Johnson Linkage" is? |
Cale Johnson thought there should be more "flexibility of transition" with the Holley carbs vs the cam and slot 660/850 center squirter (Tunnel Ram Carbs) and the Vacuum secondary carbs. So he came up with the "johnson Linkage" See Pictures.
1) He designed a PIVOT BOSS on the mainbody of the carbs. 2) he designed a slot and roller profile like the center squirter carbs but the slot went left to right vs up and down. 3) He added a link from the cam part to the secondary lever that opens the secondary blades. So now the carb had a lot more 'Transition" from just the Primary Barrels to the Secondary Barrels being opened and traveling to WOT. A very good design but a lot of parts required and EXPENSIVE per carb. Most people thought it was over-engineered. So the Later (after Johnson retired) new double pumper carbs using a simpler unique Primary plate and link now use the short rod to activate the opening of the secondary barrels. See last picture. Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 05-26-2021 at 07:17 PM. |
Long ago I ran the 800 spreadbore on a 12.5/1 396 , 3.08/3.28 duration 500/505 lift . Carb ran really nice , I liked the Holley for the ease of setting the floats . Nice carb and no need for a adapter plate to bolt on a quadrajet type intake .
1965 Pont Custom Sport 1957 Pontiac Thatcher Wagon 1957 Pont Sedan Delivery 1958 Pont Sedan Delivery 1958 Impala Sport Coupe 1958 Impala Convertible 1958 Delray Sedan Delivery ....and a few more.... |
I ran one on my GTO for years. In fact I ran both the 650 and 800 cfm spreadbore carburetors. They performed very well at the track. The 800 worked exceptionally well with a stock iron intake but it also gave good performance on a Torker intake.. One of the best carburetors I ever used.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear 85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book. 87 F350 6.9 4 speed dually A poor man has poor ways. |
#38
I switched to a Q-jet only to be able to control the secondary opening rate. Sixty foot times got better and reactions times got more consistent. The Q-jet had a noticeably smoother idle. Both carbs MPH at the track were nearly identical. The double pumper worked better when I have the stick in the car. |
#39
I ran a #6910 800 SpreadBore on my 462. Played around a bunch w/jetting & wideband. Settled on Holley's 'out of the box' jetting as the best for me. I would use one again.
#40
Based on the replies here, I am anxious to try it out, but first I need to get the car out of "body shop jail" again.
I had the trunk floor replaced and the shop had some space where I could store for the winter so I left it there. I made arrangements for him to touch up tiny rust flowers on the bottom edges of the doors this spring and then decided to have him wet sand and buff the entire car. He says lost a body man and a helper and is a month behind. Same story, different shop. I honestly believe these shops just like having a "shiny object" hanging around hoping to attract more business they can't handle.
Thread Tools | |
Display Modes | |
