Convertible Trans Crossmember Interchange??
Hello. I need a trans crossmember for a 67 GP convertible with a t400. What interchanges?
Thanks in advance!!!
I was able to take a transmission cross member from a hardtop and cut it down to work on my 68. Wasn't too tough, a few minutes with cutoff wheel and grinder. Do you have anything left of the convertible member? If you do and can lay it over the hardtop, I presume a 4 door would work too, I think it will be apparent as to what would need to be done.
(one end had rusted off of mine) I guess it would be tougher if you don't have anything at all to work from.
I assume the boxed frame cars had slightly smaller (not as long) trans crossmembers? Sent from my SM-A505U using Tapatalk
Yes ,the boxed frame cross member is shorter. My fix was a bit red neck I suppose, but it worked for me. (I had to make up the "pockets" that are welded to the frame as well.)
