Old 04-16-2021, 08:13 AM
Joe Joe is offline
Default 66 power steering pump
Hello.
have been off the site for about 10 years. Now retired and pulling out all the boxed up parts to start back on my project.
I am starting with a complete rebuild of the original p/s pump. Cannot seem to find anywhere to obtain the correct rebuild kit that includes the shaft bushing.
Does anyone have a lead or contact for this bushing and seal kit?
Thanks in advance,
Joe
Old 04-16-2021, 10:03 AM
ftwmlp's Avatar
ftwmlp ftwmlp is offline
Take at look at our hosts catalog, Ames Performance Engineering. Part numbers:
S121DH,S121DJ, S121DL
Now sure if this is what you are looking for, but maybe a place to start.
Fort Worth/Dallas TX area
1966 GTO Fontaine Blue
389 CID Carter AFB
Muncie 4 speed (orginally an automatic car)
Old 04-16-2021, 01:50 PM
Kenth's Avatar
Kenth Kenth is offline
This may be what you are looking for:
https://www.rockauto.com/en/moreinfo...350155&jsn=406
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 04-18-2021, 05:45 AM
Joe Joe is offline
Thanks to both. I decided to go with a reman pump while using my original can. What I did find is that the 66 pump uses a smaller diameter pump shaft than 67 /68. The bearing/bushing inside the pump
is not obtainable. Using a 67 pump, the shaft diameter is larger and rebuild kits are readily available and come with the bushing.
Regards,
Joe
The Following User Says Thank You to Joe For This Useful Post:
Old 04-18-2021, 01:46 PM
Kenth's Avatar
Small seal for 1966
https://www.rockauto.com/en/moreinfo...=1836584&jsn=3
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 04-19-2021, 04:44 AM
Kenth's Avatar
Regards,
Joe
FYI, the seal kit i refered to has the correct 1.250" shaft seal for your 1966 pump.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 04-20-2021, 08:32 AM
Joe Joe is offline
Thanks. I ordered a 67 rebuilt pump. The seal kit wasn't my concern. It was the long sleeve type bushing in the pump that the shaft goes through. 64-66 was an oddball size.
regards
