Old 04-08-2021, 08:18 PM
gtobob67 gtobob67 is offline
Default NOS Power Antenna Mast
NOS Power Antenna Mast part number 9795957. $300 plus shipping.
ID:	564339   Click image for larger version
ID:	564340   Click image for larger version
Old 07-26-2021, 01:34 PM
Goatboyjohnny Goatboyjohnny is offline
Any idea of the application? Looking for one that would be used in a 66-67 GTO.
Old 07-26-2021, 03:00 PM
Tim john Tim john is offline
If for a 69 Firebird I will take it. PM me if you can confirm. I will also look for application and report back. Thank You.
Tim john---
From the First Gen site:
A: The Optional Power Antenna for the 1969 Firebird was part number 9796289. The ‘Drive’ Assy itself was the same for the coupe or conv. The Mast was unique to the 1969 Firebird (pt. # 546557). Only the ’68-1969 Tempest had different Adaptors/Brackets for the Conv. No components were different on the 1969 Firebird conv. Empire was the Supplier for most Pontiac Power Antenna’s. ’11 – 22 8AAXA’ …this would be the Assy Build Date for the Antenna (Nov.22’68) The problem with the Mast would be…. since the only one being reproduced is the Mast common to the ‘A’ Bodies and Full Size Pontiacs (orig. # 541963) yu may find that fully retracted, your mast may stick out a little more than the original. The Firebird used a shorter mast than the Tempest, Grand Prix, Full-Size. With a little modification to the bottom part, you could duplicate your original.
Old 07-26-2021, 03:48 PM
It has been sold. Sorry.
