How Do I Free Up Stuck Seat Belts?
I bought a 68 GTO convertible a few months ago.
The driver and passenger seat belts cannot be adjusted as they are stuck. I squirted a little PB Blaster in the custom seat belt latch holding the belt but they're still stuck. Any ideas? |
Have you given thought to replacing them?
They are 50+ years old and that material may not be up to the task anymore. |
The Following User Says Thank You to Scarebird For This Useful Post: | ||
Im assuming you are referring to the buckle rather than the retractors, if so A bucket full of hot water with some baking soda will loosen up all the gunk build up without bleaching the color. If they are quite rusty it’s tougher to get rid of the rust.
Carefully opening up the buckle is the next step if a good soaking didn’t do the job. Especially with the standard plastic buckles you have to be really careful not to crack the cover.
My Break Away Squad 1969 Fbird (Base, 350, 400HO & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
Are the belts buckled together across the seat bottoms, did they get stuck after someone latched them?
68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
Belts are stuck at the buckles. I sprayed a good amount of WD40 in one buckle. Back seat belts are all good. It's the two front buckles that are stuck and do not allow the belts to pass through to be adjusted.
X2 it might be time for new belts if you plan to drive it
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
I have spent a ton of time on rusty stuck seat belts. If they don't come free with PB Blaster and lots of mechanical agitation... it's time to replace them.
So are you talking about those pins that release for adjusting the buckle belt length? I assumed you meant they were clipped together & wouldn't unlock. If you have the std belts the plastic covers can be removed to expose a little more. have to be careful so you don't break them, but its not too bad.
Removed the two front stuck belts and sent them to get rebuilt.
The Following User Says Thank You to 71 T/A For This Useful Post: | ||
Link Please? Wondering if they are the deluxe or plastic and do they restore both types.
Soaking the belts in anything besides water would cause me concern given their age. Glad you opted to seek a professional option, thanks in advance. Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
soak the belt systems in a 5 gallon bucket with warm water & Tide or similar detergent overnight.
Next day take em " squeegy them" on the bucket edge and resoak a few times, and run the buckle up and down. Put out to air dry. supple. You can rebuild the buckle alot easier now too. toothbruh helps. |
Search on youtube. Several good examples on how to take apart and clean up stuck buckles...
"Bill"! |
The Following User Says Thank You to bill ryder For This Useful Post: | ||
